Can anyone tell me what could cause this problem. I have a KOSS KS3120-2 DVD Player and put a DVD-R disc inside (works on 2 other DVD Players) and I have picture but really low sound (So low that the TV has to be on full blast to know that a little bit of sound is coming through). I took it out and put in a normal DVD now they're all doing that. Was working when I used it on other DVD's a couple days ago! HELP. Thanks.
Closed Thread
get a new dvd player ...
or
also make sure you didnt switch the audio out options , like turn off the digital out or something .. go through the set up menu and check everything .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
I checked all the settings (There's not many). Can a DVD-R do this to a DVD Player or is it a coincidence?
well i once played a svcd on a apex 1200 and got a no media present error and it would never play another svcd after that -- but would play everything else..
so im not going to say its impossable, though seems highly unlikely .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Your dvd lens are dirty ,but if you purchase a good dvd lens cleaner like Discwasher it might wind up costing more than the dvd player itself ,remember good things are not cheap and cheap things are not good .If I were you I would toss the koss (no punt intended) and get a brand name like panasonic or sony etc.
Only one thread at a time. Thanks
http://www.videohelp.com/forum/viewtopic.php?t=255145
so he locks the ONE THREAD i post an answer in and leaves the other one up .....
what a guy !"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
DVD Chapters messed up after authoring
By dexter30 in forum Authoring (DVD)Replies: 13Last Post: 25th Mar 2011, 18:12 -
Need codes to convert Australian DVD player into a multi region DVD player
By Seajacb123 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 13th Oct 2010, 01:00 -
Messed up finalizing a dvd
By spunon in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2009, 14:06 -
Audio messed up when burning .mpeg on DVD +R
By greenda4 in forum AudioReplies: 16Last Post: 19th Nov 2008, 15:52 -
my DVD and HDD messed up
By goodguyswearblack9 in forum DVD RippingReplies: 8Last Post: 20th Apr 2008, 02:11
