Hi there,i have a DTS audio wav file,which i have tried to play with wmp and all i get is a sound like a record being scratched by a needle(if you know what i mean).
Do i need to install a particular codec or something to play this file?
Thanks for any help given.
use the search function -> this question had been answered a billion times (Moderator - donīt you think itīs time for one more sticky
try VideoLan Player (VLC) -> itīs the only player so far I know which could handle DTSWAV
Burn it to a CD and put it in you DVD player. If you have digital out to your amp, you will hear it.
donīt forget:Burn it to a CD and put it in you DVD player. If you have digital out to your amp, you will hear it.
-> requires a digital connection (optical/coaxial) no L/R Chinch!
doesn't latest ac3filter rc5 support dtswav?
http://ac3filter.sourceforge.net/dow..._1_01a_rc5.exe
from the history
+ DTS decoding support (including AVI/DTS and WAV/DTS)
as far as I tested it with f.e media Player classic /WMP this works only with padding DTS files - nope with DTSWAV
Tried this still no joy.Originally Posted by Baldrick
Transcode 7.1 DTS-Master Audio to 7.1 L-PCM (.wav/.aiff)
By nateo200 in forum Blu-ray RippingReplies: 10Last Post: 27th Apr 2012, 15:57 -
5.1 audio question - is a single .wav file true 5.1 DTS?
By jazzsander in forum AudioReplies: 5Last Post: 18th Apr 2012, 21:00 -
Any ideas why this file won't play in my BDPlayer?
By valp in forum Video ConversionReplies: 7Last Post: 1st Dec 2011, 00:09 -
Improving the conversion of a .mkv file (DTS) to a .mkv file (AC3). Ideas?
By mdelisle1 in forum Video ConversionReplies: 11Last Post: 19th Jan 2011, 10:50 -
.wav and .dts file problems
By bskies in forum AudioReplies: 2Last Post: 20th May 2007, 03:23
