VideoHelp.com Forum
  1. Hi all, I've just bought a cheap dvd player from Wal-Mart. It's Cyber Home, and it won't play my NTSC region 3 DVD movies. It is multi-system, NTSC and PAL, but it ain't playing my movies. What's up, does anyone have any ideas?
  2. Originally Posted by JonPumin
    If you're in the US, you're in Region 1. You will need the hacked firmware to play DVDs from other regions.
  3. Member drjtech's Avatar
    Have you applied the Region Free hack?
    Menu 1 9
    select 0 for region free
    If that doesn't work check:
    http://www.videohelp.com/dvdhacks.ph...ome+CH-DVD+300
    If you really meant CVD 300 and not CH-DVD 300, then I'm at a loss.
    -drj
    They that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
    --Benjamin Franklin
  4. Member Noahtuck's Avatar
    You should not have to mess with firmware at all, just do what drjtech
    I have had this player for over a year and it works great on any dvd from anywhere, any region from just changing the region to 0 on the player.
    Originally a member since 2001, LONG LIVE TARAN's!!!
  5. drjtech, it's indeed a CH-DVD 300 model. I'll try to hack it tonight and see if it works. Thanks for all the replies!
  6. Member jackal70058's Avatar
    The CH-DVD 300 is the easiest to Region Free. I only had mine about a year because the power supply is defective.
  7. It does work y'all! Thank you so much for all the replies.. :D
  1. Replies: 6
    Last Post: 2nd Aug 2011, 10:52
  2. Need help regarding video output ofHarman Kardon HS-300 home theatre system
    By dissident187 in forum Newbie / General discussions
    Last Post: 23rd Aug 2009, 05:30
  3. Questions about Media Player Classic Home Cinema
    By Seeker47 in forum Software Playing
    Last Post: 31st Mar 2009, 11:50
  4. Replies: 9
    Last Post: 21st Nov 2008, 18:14
  5. Replies: 2
    Last Post: 20th Aug 2007, 02:37
