Hey all,
I just got a DVD burner so im new to this. I wanted to make a DVD with no menus. I just want it to start when I put it in. This is going to be a trailer disc. What I do is I master .mov movie trailers and cnovert to DVD with tmpge. I also have some VOB sound trailers (THX, DTS, etc) that I want to add. At the end of the process I want to have a DVD that will play movie trailers and then a sound trailer. How can i do this with the different files? Can I burn a DVD with mpeg and vob files? Any help would be great!
-BSR
Results 1 to 18 of 18
DVDLab Pro will do it.
Cheers, Jim
My DVDLab Guides
Yo!
VOB files are just containers for MPEGI / MPEGII video streams and audio streams such as AC3 / MPEG LayerIII
DVDs require (at the very least) a VOB file & extract these streams and play them...
Read Reboot most excellent guide on how to then author a DVD as he suggests.
AndyWork you bloody thing....
Thanks guys. When I rip the VOB files, will it keep it's sound and anamorphic properties when I reburn?
-BSR
Yes, you're not encoding anything, just getting the mpeg out of it's "carrying case" (the .vobs).
FYI, DVDLab can import .vobs, and join them as one continuous movie.Cheers, Jim
My DVDLab Guides
Thanks reboot. I'll follow your guide. I'll probably get lost and burn down my house though
-BSR
Before you set anything afire, post questions here.
I check in about every hour or so during the day.Cheers, Jim
My DVDLab Guides
what about the other way. my PVR recoprded )PC based pvr) recorded some mpeg2 files and to MALE vpb's out of these I also need all the suport files (bup ifo etc..) so that DVD Shrink will see it properly so O can shrink it (its 16gig (super bowl)
I usually only play with mpeg1 but for this I wanted to dabble with mpeg2 since I wanted to make a dvd video not just a dvd's with mpg's on it and figured go higher quality from the get go
Chris Taylor
http://www.zodiacreview.com/
WTF are "MALE vpb's" ?
Load your mpegs into dvdlab, compile, shrink, burn.Cheers, Jim
My DVDLab Guides
I don't usually go for wizard-based, all-in-one solutions, but to create a simple DVD with no menus out of anything, WinAVI converter is hard to beat. I can dump a list of mpeg, divx, avi files and get a ready-to-burn VIDEO_TS folder. It's even faster at encoding from divx to VOB than Mainconcept is at encoding divx to MPEG2. I'm just not sure about importing VOBs, but I think it would do it.
Yes, WinAVI will import .vob's.
It may be faster, but it's not better
Cheers, Jim
My DVDLab Guides
alas tmpgenc dvd author appears to have a 9gig limit it will not make a dvd larger than that
so I will have to chunk the file into smaller parts and then vob it and then recombine and shrink it (will never use dvd standard record quality again
all I wanted was something to make vobs so I could shrink and edit with dvd shrink.
I will looking into the winavi program.
I was hopeful for dvd lab since it will let me make OUT of spec dvd's but it does not support mpg1
DOLT that should have been MAKE Vob's (sloppy fingers
Chris Taylor
Yes, dvdlab will import mpeg-1 files, and let you reauthor them. It will put up a warning, but this can be ignored, and should still play on most players.
DVDLab will also take files larger than 9 gig, and output the structure to use shrink.Cheers, Jim
My DVDLab Guides
oooooohhhhhh gonna have to try this
this must be new a year ago there was no mpg1 support
Chris Taylor
http://www.nerys.com/
Let me clarify, DVDLab Pro will accept mpeg-1. I haven't used standard version in over a year.
Cheers, Jim
My DVDLab Guides
dvd lab does but I get the imjplication that it wants to transcode the audio. I will look into pro.
Chris Taylor
Cheers, Jim
My DVDLab Guides
No it does not "have" to be transcoded the software just insists on it
grrrr
then its just not worth my time sadly. I have WAY to many gigs of mpg1's to bother transcoding (would LITERALLY take thousands upon thousands upond thousands of hours) and then I would have to maintain TWO copies one as mpg1 (source) and one transcoded in case I have to burn again. no thanks.
why will none of these program LET me do it without transcoding I am almost CERTAIN dvd players would play such a disc just fine. I would at least like the oppurtunity to find out
heck JUST the video from our trip to cancun totals nearly 20gig
if people want to see my video on dvd they will just have to get a dvd player that can handle mpg on dvd ie as files.
Chris Taylor
problems making dvd from vob files only
By Dr_Sanguinary in forum Newbie / General discussionsReplies: 3Last Post: 17th Nov 2009, 07:20 -
Making DVDs from backups of VOB files
By kirklt in forum Authoring (DVD)Replies: 1Last Post: 26th Aug 2009, 08:52 -
DVD Demuxer tool making 0kb .VOB files
By Madvillain in forum DVD RippingReplies: 5Last Post: 6th Jul 2009, 04:11 -
Making a DVD menu from .VOB files created by FAVC?
By whatever911 in forum Authoring (DVD)Replies: 9Last Post: 16th Feb 2009, 03:13 -
making movie from many mepg/vob files
By volam in forum EditingReplies: 3Last Post: 10th Apr 2008, 10:33
