I have authored a few DVDs using DVB captures, native resolution 528x480. These play fine on my Sony & Mitsubishi DVD players (and look superb). Unfortunately, the video is completely garbed on my Philips 642. It plays SVCD-resolution mpgs burned onto DVDs just fine, but not the DVB resolution. Is there a way to make non-standard DVD resolutions viewable? Is there a header that can be tweaked or something?
Also, what is the upper limit on Divx resolutions that the 642 will play? I have an HDTV-sourced Divx at 1280x720 that will not play. Thanks in advance.
I have a similar problem, although I'm in North America so my vertical resolutions are all 480.
Any how, I have this player for MPEG4 and such, but it wont play DVB files captured and burned onto an ISO dvd or CD.
It WILL play these files if I go through the process of authoring them though.
Some of the captures have to be DVDPatched to DVD reslolution before the authoring program will accept them.
I'm looking for a quick and dirty way to make these mpeg2 streams playable as well.
Kremb, we the opposite problem on the same DVD player. Weird. I am able to play DVB-captured MPGs on ISO cds or DVDs but there is no sound because of the ac3 audio. When I author MPGs to DVDs, the sound plays but video is garbled.
Problem with philips dvp 642/37 after choosing progressive scan option.
By vinland in forum DVD & Blu-ray PlayersReplies: 1Last Post: 3rd Jun 2010, 19:21 -
Philips DVP-642 16:9 Display
By wulf109 in forum DVD & Blu-ray WritersReplies: 4Last Post: 27th Jan 2010, 12:39 -
Philips dvp 642 help?
By imemine in forum DVD & Blu-ray PlayersReplies: 7Last Post: 3rd Feb 2009, 02:22 -
First Generation Philips 642 Stopped Playing DVD+R DL
By somebodeez in forum DVD & Blu-ray PlayersReplies: 7Last Post: 4th Sep 2007, 16:57 -
Problem playing AVI on Philips DVP 642K
By yohu123 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 20th Aug 2007, 09:28
Statistics
Newest guides
Latest tool updates
New media comments
