VideoHelp.com Forum
  1. I was wondering if you need a Lite-on DVD burner to use KProbe or if it will work with a Lite-on CD burner/DVD-ROM drive.
    I believe it will work with all lite-on drives (even rebadge), but why would you want to scan something that you did not burn?
  3. I already have a Pioneer burner. so I would urn with that.
    Some, if not most, Pioneers are actually Lite-on. So you might be able to use kprobe. Alos, you can use improved liteon firmware if you want. You could also use CDspeed since it measures about the same thing
  5. Originally Posted by yellowsugga
    It works in the meaning that you will see some graphs but the results from Lite-On combo drives and DVD-ROMs are not considered to be reliable.
    No.
    I confused Pioneer with Sony. But I was looking at CDfreaks and saw where there were posts with kprobe scans from pioneer drives.
  7. I'm sure the later revisions of DVDInfoPro can run KProbe type of PI and PO scans on Pioneer drives. I have a Pioneer 107D and I get very good scans using DVDInfoPro.
    DVDInfo and Nero CD-DVD Speed tests are fine on most drives, including Pioneer. kprobe is overrated. In fact PI/PO tests are overrated.
  1. Replies: 6
    Last Post: 7th Feb 2012, 14:17
  2. Replies: 2
    Last Post: 6th Oct 2009, 12:56
  3. is lg ggwh20l and kprobe compatible ?
    By deejay.2001 in forum DVD & Blu-ray Writers
    Last Post: 4th Sep 2009, 01:41
  4. Replies: 3
    Last Post: 31st Aug 2009, 17:55
  5. Time/Date Stamp - DVD, Hard Drive, and/or flash drive camcorders
    By vanjh9 in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 2nd Feb 2009, 18:38
