I've got a Divx file that's encoded as HRHD, which won't play on my Pioneer 575A - I guess because it's hi def. There's no picture, but the DD 5.1 sound plays OK. I'd really like to watch this file for the DD sound, is there a way of converting the file to work on a standard definition display?
Thread: HRHD Files on Pioneer 575A?
The file wont play because the screen size is too big. The best thing to do is resize using Virtual Dub. Load the file into VD and click; video, Filters, Add & then choose the Resize filter. Change the size to something like 640x272 or another suitable size, then choose Bicubic from the Filter mode as this will provide the best quality if you are downsizing. Then just OK everything and click; File, Save avi & save the file. (give a different file name to protect the original in case something goes wrong). You may want to investigate the screen size to make sure you get the best possible conversion.
Thanks for that, I'll give it a go.
Mark
I followed these instructions, seem to go OK. When I first did it the resulting file was huge - looked to be uncompressed, so I selected "Compression" under the "Video" menu and selected XvID. I left the compression on the default of 271, which resulted in low quality. Any suggestions of a good compression Bitrate to use?
Mark
How to access video files from Pioneer DVR 540HX on the PC?
By vcruzmed in forum DVD & Blu-ray RecordersReplies: 17Last Post: 15th Nov 2010, 13:43 -
Divx 3 AVI files for my Pioneer AVIC D3
By cbeausoleil in forum MacReplies: 5Last Post: 19th Aug 2008, 22:59 -
Pioneer DVR-112 seems to stop my Pioneer DVR-115 from being recognized
By Thommo1978 in forum DVD & Blu-ray WritersReplies: 9Last Post: 3rd Feb 2008, 06:02 -
Pioneer DV-400V Any way to play standard MPG/MPEG-2 files from USB or disc?
By flobie11 in forum DVD & Blu-ray PlayersReplies: 7Last Post: 2nd Feb 2008, 06:09 -
How can I access files from pioneer 531 hard drive using computer
By hlg1111 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 25th May 2007, 00:08
Statistics
Newest guides
Latest tool updates
New media comments
