hello friends,
iam having nero 6 burning software on trial. for couple of days it was doing fine. but i tried to burn an .avi file which i converted from .rm
but iam getting errors.
it is saying burn process completed successfully(but nothing on CD-R) but then getting a message
data verification started
SAMSUNG CD-R/RW SW-252S
read errors from sector 225 to 374
there r many errors of this same type only difference is the sector range.
from yesturday night it is verifying the compilation. but its not yet done.
i tried 2 times but same errors.
the movie is running good in the media player.
please help
Thread: problem burning CD-R
Don't you have to convert the .avi to mpeg before burning to VCD/SVCD?
I don't think you can burn .avi directly with Nero without a plugin. And the
conversion takes a long time.
Could be bad media,try again or a better brand.Do you mean mpg instead of avi?
Ben Johnson-I didnt take any stereos!
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Problem burning the first SL DVD+R after burning DL disc...
By starmen in forum DVD RippingReplies: 0Last Post: 5th Apr 2005, 12:46 -
problem burning backups, burns ok but not burning correctly
By xaznx in forum DVD RippingReplies: 6Last Post: 10th May 2004, 01:06 -
Burning .Img -> NO Problem, But burning .VOB aint wo
By chillyah in forum DVD RippingReplies: 0Last Post: 8th Jan 2004, 10:04 -
EMTEC DVD+R burning problem (or maybe software problem?)
By countryboy in forum DVD RippingReplies: 2Last Post: 20th Oct 2003, 09:09
Statistics
Newest guides
Latest tool updates
New media comments
