This is a recent problem. When insert a VCD (home made/CD-R) my dvd player try to load the disc and sound "tracking" until says "NO DISC". Only play DVDs and Music CDs. It was playing VCD movies with no problem till now.
Saludos,
Results 1 to 9 of 9
Probably your media.
does your player play all format of VCD? There are at least four standards for VCD.
What is the make and model of your player?
If I can find the manual for it then I can determine this.
I have seen players that only play one type of VCD.snappy phrase
I don't know what you're talking about.
My DVD player it's a DAEWOO DHX-100 Hometeather (an old model) and I have no manuals. I was able to play VCDs for months with no problems.
Saludos,
See if you can play your VCD on another player or a PC. It could be a problem with your disc.
Have you recently changed you cdr brand?
Try burning to a cdrw instead of cdr.
If it works, your cdr blanks are dodgy.
No, the VCD play well in PC. This is a recent problem. I was read before that VCD (home recorded) can damage the DVD player. It's that true? Can anyone help me to find my Daewoo Hometheater manual?
Thnaks.
Hello,
No a VCD can't damage a dvd player. MANY can play VCD on a cdr or cdrw disc. All that will happen if it doesn't have vcd capability is "NO DISC" will be displayed.
KevinDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Have you changed your burning program? Some programs burn disks that incompatible with some DVD players.
Toshiba Sat. A200-AH6 laptop DVD drive cannot read DVD DL discs
By MeekloBraca in forum DVD & Blu-ray WritersReplies: 11Last Post: 9th Dec 2009, 02:27 -
Any Way To Get XP To Read UDF2.60 Discs?
By Anakin in forum Authoring (DVD)Replies: 3Last Post: 13th Aug 2008, 18:52 -
Standalone DVD Player to read iso image and VTS files
By bluemoss in forum DVD & Blu-ray PlayersReplies: 6Last Post: 19th Nov 2007, 14:45 -
Philips 20X SPD2413BD won't read 8cm DVD-R discs
By nlec in forum DVD & Blu-ray WritersReplies: 1Last Post: 5th Jun 2007, 11:03 -
Can any DVD drive read DVD DL discs?
By alegator in forum ComputerReplies: 3Last Post: 5th May 2007, 20:45
