Ok its not a complete hack, but its a start. Here is what I did and the results:
1. Using a PDA with TVremote control software I uploaded a Awia ccf file found at this web site: http://www.remotecentral.com
2. Turned on the player without a disk.
3. Pressed clocked which gave me Servo Adjust completed sign on my L300.
4. Now I pressed the sleep tab which in turn gave me a Completed Cold Start.... Current Ver: XXXXXX:XX:XXXXX Region Code: 9 sign.
After this I inserted a region 2 disk to no avail, as it still gives me a wrong region code error.
I now pressed just the clock tab on my PDA followed by inserting a region 2 disk. This still didn't work, however the warning sign came up as a wrong TV system instead of the usual region code error message.
Now I know that the L300 its just a software restriction which prevents PAL and not a hardware. I know this because I attached an external Pal signal which worked perfectly, sound and color, for a brief second or two, so my guess there a lock in the firmware as well.
One further function I found on the awia remote is the mode tab which gives me color bars. Perhaps this may have something to do with the TV system lock.
Finally, I have noticed that once I turn the player off and on again I am promted with the select langauge display and everything returns back as it was, so nothing is saved. There must be some additional steps which I must be missing and any help will be greatly appreciated.
Many Thanks in advance.
Results 1 to 1 of 1
samsung ht-tz222 hack
By autoelec69 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 24th Oct 2010, 14:22 -
Need region hack for Samsung BD-P1580?????
By samsungnewowner in forum DVD & Blu-ray PlayersReplies: 8Last Post: 16th Apr 2010, 18:34 -
Made my Samsung dvd-1080P9 region free - but pic went b/w
By pjotrrr in forum DVD & Blu-ray PlayersReplies: 2Last Post: 28th Aug 2009, 14:18 -
hack code for Samsung HT-TWZ312 ?
By columboy in forum DVD & Blu-ray PlayersReplies: 3Last Post: 28th Oct 2008, 07:02 -
samsung dvdhd845 hack help
By joshe47 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 31st Dec 2007, 09:45
