i have a dvp642/37 which came with 0531 firmware. bought it recently. nothing problematic enough to force me to return it. but i think i might've found another problem. not sure if it was mentioned though.
anamorphic DVDs work fine with the WS option enabled on the DVD Player (instead of LB4:3 or PS4:3, i chose 16:9 when connecting to my widescreen tv). however, when i put in a 2:35AR or 16:9AR movie (or something close to these ARs) it'll put black bars to fill a 4:3 resolution. so on my widescreen, it won't be displayed correctly. only choice i have is to use my TVs option to stretch it up/down, which will, of course, distort it, degrading the quality (even more).
anyone have this problem? any fixes?
Results 1 to 1 of 1
Remote for Philips DVP642
By Melina in forum DVD & Blu-ray PlayersReplies: 2Last Post: 10th Jun 2010, 21:54 -
Philips DVP642 finally died...
By Krispy Kritter in forum DVD & Blu-ray PlayersReplies: 0Last Post: 3rd Feb 2009, 13:06 -
PHILIPS DVP642... how do I upgrade the firmware?
By mummer43 in forum DVD & Blu-ray PlayersReplies: 39Last Post: 14th Jan 2009, 18:45 -
Output resolution for Philips DVP642
By cheerful in forum DVD & Blu-ray PlayersReplies: 1Last Post: 2nd Aug 2007, 23:41 -
Philips DVP642 and DivX 6/Ultra
By cheerful in forum DVD & Blu-ray PlayersReplies: 2Last Post: 2nd Aug 2007, 11:43
