VideoHelp.com Forum
    I have a lot of codecs, most of them new or fairly new. When I watch a video, parts where the color is darker (like black hair), the color shinny.
    Never seen that on standard monitor.
  2. Only on video and not on pictures? On some video cards (such as mine), there is a "video overlay" option in the advanced settings where you can adust brightness, contrast, color, etc. You could try messing with that.
  3. Member anitract's Avatar
    Sorry to bump an old post...but, I think what you might be experiencing is color dithering from your LCD panel. If your LCD is a TN-Film based panel (as opposed to an MVA/PVA, or ISP), it can't display 16.7 million colors natively (it is in fact 6bit, as oppoed to 8bit)...
    ...so to compensate, the monitor "emulates" / dithers the the colors it can't natively display by switching back in forth between 2 similar colors so fast that your eye "sees" the right color. This can cause a shimmering/sparkling affect in solid color areas on a screen.
    So how to tell if you have a 6bit or 8bit panel? Well, most 6bit panels are are the low response timed ones (8ms/12ms/some 16ms), as opposed to 8-bits being around 25ms...also the 6bits typically have a lower viewing angle.
  1. Best lcd monitor for video restoration
    By buckethead in forum Restoration
    Last Post: 14th Apr 2011, 08:36
  2. LCD Monitor Problem
    By Soopafresh in forum Computer
    Last Post: 27th Apr 2008, 03:11
  3. Weird Toshiba HD-A2 problem on a standard PC LCD monitor
    By danimal99 in forum DVD & Blu-ray Players
    Last Post: 9th Nov 2007, 12:07
  4. LCD Monitor...is it a problem?
    By ron spencer in forum Computer
    Last Post: 24th Sep 2007, 07:24
  5. Problem viewing video on new 2nd monitor
    By ggmac1972 in forum Newbie / General discussions
    Last Post: 24th Aug 2007, 12:48
