VideoHelp.com Forum
  1. I have a Panasonic E-50 and always have used TDK DVD-R 2X
    I no longer am able to find this 2X TDK DVD-R and only am finding the stores to have the TDK DVD-R 4X . Can you please tell me if this 4X will work just as good as the 2X in that, it will record just as good as the 2X did and will play back just as good on other players as the 2X does?
    I do not understand what the 2X and 4X really means with this but, I am asking here in hopes you can let me know.
    Thanks so very much for your help!
    If i were you I would go to Panasonic's site and search for info on the E-50 and high speed DVD-R discs. 2x, 4x, etc refer to the recording speed of the discs.
  3. Gen-An,
    I cannot find anything. I really need to know if I can use the TDK DVD-R 4x to record on the Panasonic E-50 and also if they will play as perfect as the 2X does on players. Please can someone let me know?
  4. Member HatchetMan's Avatar
    Have you tried Panasonic's or TDK's customer support? It's usually just a matter of a firmware update, if anything at all.
  1. Can't burn DVD using TDK burner
    By tee jay in forum Mac
    Last Post: 16th Sep 2008, 14:01
  2. TDK DVD+RW format before use
    By nobbydadog in forum Media
    Last Post: 30th Apr 2008, 08:55
  3. TDK Professional DVD-R media ID?
    By lordsmurf in forum Media
    Last Post: 15th Dec 2007, 11:08
  4. Sony and TDK DVD Discs
    By Happs in forum Media
    Last Post: 29th Jul 2007, 14:43
  5. TDK brand DVD+Rs- These any good?
    By Super Warrior in forum Media
    Last Post: 28th May 2007, 14:19
