VideoHelp.com Forum
  1. Member nick101181's Avatar
    I have a dvd that a friend encoded and made of and old 1983 wrestling event that was on tv. He didn't know how to get rid of the hiss in the audio. I've used dvd2avi to demux the audio with a delay value. then I used besweet to convert the ac3 to wav while using the delay option from dvd2avi. I then fixed the wav and encoded it to the same type of ac3 that it was (2ch stereo). I tried to pick load dvd video in tmpgenc that way it would have all the correct chapters and all and just replace the audio with the new one. when I try to output the file it goes for about a minute then says done, but the files are small and it didn't even do it properly. any ideas how I can do this ? thanks
  2. Open tmpgenc, cancel the wizard, select File, mpeg tools, simple remux.
    Mux the new audio with the old video. Author, Burn.
    Cheers, Jim
    My DVDLab Guides
  3. Member nick101181's Avatar
    This is kinda a problem because I used dvd2avi and I got the whole audio file and the files from the dvd are vobs. the audio file is not split up evenly with the vobs.
  4. Load the .vobs into dvdlab. Select "Join".
    Open the mpeg in tmpgenc's mpeg tools, demux.
    You now have a complete audio file.
    That's just one way, I know there are other ways to extract .vobs
    Cheers, Jim
    My DVDLab Guides
  1. Replacing a DVD audio track
    By mltwitz in forum DVD Ripping
    Last Post: 13th Jun 2010, 19:58
  2. help replacing audio on DVD
    By fullbohr in forum Audio
    Last Post: 12th Nov 2009, 20:34
  3. replacing audio on a dvd
    By phillbrett68 in forum Authoring (DVD)
    Last Post: 11th Dec 2008, 00:11
  4. replacing audio on a dvd
    Last Post: 7th Dec 2008, 01:00
  5. Replacing DVD Audio stream.
    By GangstaRap in forum Authoring (DVD)
    Last Post: 27th Feb 2008, 06:21
