VideoHelp.com Forum
  1. Does anyone know of software that will allow me to specifiy a folder and then the software will play all the video files in that folder in separate thumbnails?
    I have a folder containing hundreds of video files in various formats with undescriptive file names. I'm hoping to avoid the time-consuming task of opening each file one-by-one to see what's in them.
    Using the Thumbnail view in Windows Explorer, I can see the first frame of each video but that often doesn't tell me what's in the video. I really need to play the video. Thank you.
  2. It wouldn't suprise me if BeOS had something like this, since it was known for its multimedia capabilities. I'm not sure if there is a windows app that does this though.
  3. Member chongo's Avatar
    The best idea I have is to load them all into a Win Media Player playlist, then with the file locations open on the left half of the screen, and WMP on the right, you could quickly flip through and re-name.
    The program your looking for is called, "ThumbsPlus" it can be found at www.cerious.com
  1. Western Digital Media Player Thumbnail help
    By DebCoom in forum Media Center PC / MediaCenters
    Last Post: 19th Feb 2011, 07:06
  2. Video Thumbnail Maker
    By WubbyNuts in forum Editing
    Last Post: 29th Nov 2009, 15:43
  3. Thumbnail problem with Western Digital HDMi Media Player
    By paulpeople2476 in forum Media Center PC / MediaCenters
    Last Post: 26th May 2009, 22:51
  4. WD TV Media Player Thumbnail issue
    By dudeman316 in forum DVB / HDTV
    Last Post: 14th May 2009, 06:57
  5. Animated thumbnail (playing thumbnail) in DVD menu??
    By blizzery in forum Authoring (DVD)
    Last Post: 9th Nov 2007, 01:46
