If you want to add to the list, Please use the example below
example:
Media name:
Prodisc hub printable
Printable surface:
white matte
Print area:
118mm x 22mm
List:
GQ (Optodisc) white matte
118mm x 39mm Photoshop Template
Optodisc white matte hub printable Not confirmed
117mm x 24mm Photoshop Template
Prodisc white matte or silver matte hub printable
118mm x 22mm Photoshop Template
Prodisc Silver matte
118mm x 33mm Photoshop Template
Ritek white matte hub printable
Ritek white matte
118mm x 42mm Photoshop Template
TDK "PrintOn" white matte
117mm x 39mm Photoshop Template
TY white matte or Water Shield hub printable (Fixed off center hole)
119mm x 22mm Photoshop Template
[s:e131f6f55f]TY white matte hub printable
119mm x 23mm (actual 118.5mm) [/s:e131f6f55f][s:e131f6f55f]Photoshop Template[/s:e131f6f55f]
TY white matte
118mm x 44mm Photoshop Template
Verbatim white matte hub printable
119mm x 21mm Photoshop Template
119mm x 36mm Photoshop Template
Verbatim DataLifePlus DVD+R DL white matte
119mm x 35.5mm Photoshop Template 119mm x 36mm
Edit:
Changed subject title after move
updated list
removed poll
sorted by media name
add media
add templates
Results 1 to 30 of 61
My comments added to stiltman:
Print area:
119mm x 21mm (Verbatim hub printable)
118mm x 22mm (Prodisc & Ritek hub printable)
118mm x 42mm (Ritek non hub printable)
118mm x 44mm (TY non hub printable)
118mm x 33mm (Prodisc Silver)
117mm x 39mm (New TDK "PrintOn")
116mm x 43mm (Epson software default
That would be nice. Especially since I can't find that info for the Memorex ones Epson suggests (no flaming, they work for me). Of course, maybe that's why the software has the defaults it does.
Don't need a new forum just keep this as one of the threads that is constantly on top (STICKY)
What We Do In Life, Echoes In Eternity....
It's not a forumOriginally Posted by Capmaster
Its just a description section in the media list
So change your vote to a yes thenOriginally Posted by Capmaster
Thanks CapOriginally Posted by Capmaster
118mm x 33mmThe silver hub-printable Prodisc media I have has the same printable area as the white hub-printable Prodisc. I too thought that the printable area was only 33mm and printed my first disc with that dimension. I think one is fooled because the print area extends beyond the dye portion of the disc. The absence of the dye underneath makes that portion of the print area appear lighter in color, as if the printable surface didn't extend that far. But it really is printable up to 22mm just like the white.118mm x 33mm (Prodisc Silver)
that's why I put hub printable next to the ones that are hub printable.
I can guarantee 100% that the Prodisc silver matte discs that I have right here can not be printed to the hub
I will however, add silver matte hub printables
Yes, you did. But since 33mm is exactly the dimension that I first (incorrectly) measured on my silver Prodisc, I thought you'd made the same mistake that I did. I apologize for any confusion I caused.that's why I put hub printable next to the ones that are hub printable.
BTW, where did you get your non-hub printable Prodiscs?
Supermediastore Prodisc S03 about 9 months ago. I still have 10 left out of 50. Never really use them since I do not care for the holographic look. I just use them now for my home movie creations
I tend to agree with you on this one. It does look okay for a couple of labels that I made up myself, but mostly it looks kinda strange. I do like the texture of the silver media better though. It almost seems to hold the ink better.Never really use them since I do not care for the holographic look.
Stiltman,
Please edit to add the following
Verbatim white matte (non-hub) are 36mm - 119mm
More info: -R 8x MCC 02RG20
edit: I'm not sure why there is a ? after ritek non hub. Yes they are matte.
Thanks Rick.
Yeah I didn't know about the Ritek non hubs
I know it would be nice to have the media codes but then it would get too complicated
Think that can wait for the info to be added to the official media list by Mr. B
Added Photoshop templates
I have a bunch of Prodisc silver matte 4x DVD-r that I got from supermediastore.com. Their product ID is DVD01X0121 and the media code is MCC02RG20. They are NOT advertised as inkjet printable, but are they? At the time I bought them I wasn't interested in printing on them, but now I am (I just ordered an Epson R200). Anybody know?
You might want to start a new thread for this question.Originally Posted by Gorganzola
I always thought that the MCC id was only for 8X media. I have some really old silver matte inkjet printable from SMS and the id is S03
Ok Stilt, I started a new thread as you suggested. Mods might want to remove this post and my last one from here.
Optodisc 100 pack 4.7GB 4x DVD-R White Inkjet Hub Printable Bulk
Ratings:
Product Code: DVD01X0092-100
Manufacturer: Optodisc
Mfr part #:
How can I get the dimensions for these disks? I am new to this and these may not be the best disks out there, but they serve my purpose of learning.
Measure them with a ruler or something and I'll add it to the list.Originally Posted by psigna
My husband had one of those things, don't know what it is called, but it was for measuring diameters. I got 24 for the inner and 117 for the outer rim.
hub printables are usually 21-22mm...Hmm
added to the list
These have a small circle just before the printable part starts. I measured without that part and they are about 22. BUT the printer does not print on this part.
What type of printer and software?Originally Posted by psigna
Epson Print CD and epson R200. The part that I am talking aobut is on the cd itself, before it is printed.
CD?
I added it to the list with the measurements you provided. Also created a template based on those measurements
Quick Media Converter lifehacker.com most popular free windows app 2008 ?
By balou in forum Latest Video NewsReplies: 77Last Post: 17th Mar 2009, 03:09 -
relative quality and best burn speeds for some popular media
By JohnnyBob in forum MediaReplies: 32Last Post: 8th Feb 2008, 18:44 -
Printable DVD media
By klsparrow in forum MediaReplies: 2Last Post: 5th Jul 2004, 05:08 -
DVD and CD Printable Media
By mohawkcr in forum MediaReplies: 2Last Post: 2nd Mar 2004, 10:21 -
Who's using printable DVD media?
By Redd in forum MediaReplies: 3Last Post: 12th Nov 2003, 13:54
Misunderstood ya stilt
