VideoHelp.com Forum
  1. HI all,
    I have had this player now for a long time but I have been noticing that movies I burn on it start to skip while original dvds play fine. The weird thing is, is that most of these movies played fine before but now going back and watching them later they are skipping. I used a lens cleaner and I have the most up to date firmware being 3.02 for it. Any ideas on what to do to get this resolved.
    PS: The burned ones play fine on my son's Xbox. Just to rule out the discs
  2. Had the same problem... I did a "tune-up": cleaned the lens with one of them cd/dvd clearers, the one with the little brushes and lubricated the rails with tri-flow lubricant... and so far, it has not skip.
    I was told that it also may be that the intensity of the laser has reduced and may need adjustment... I am just quoting since I do not know if it is correct or how do it.
    Hope this helps... at least the tune-up part :^)
  3. Yeah like I said...i did the lens cleaner part so far...but it only seems to happen with the burned discs and not the store bought dvds. Very weird.
  1. 2001-2010 my capture cards - comparison screenshots
    By vaporeon800 in forum Capturing
    Last Post: 7th Dec 2011, 18:58
  2. replacing a DVD burner on my polaroid 2001
    By majel in forum DVD & Blu-ray Recorders
    Last Post: 9th Aug 2010, 16:04
  3. LVD-2010 media server software
    By cotc2001 in forum DVD & Blu-ray Players
    Last Post: 28th May 2009, 04:32
  4. New site with codec comparisons going back to 2001
    By Tab in forum Latest Video News
    Last Post: 1st Nov 2008, 10:32
  5. LiteOn LVD-2002 DivX/MPEG-4/DVD Player
    By Roundabout in forum DVD & Blu-ray Players
    Last Post: 25th May 2008, 04:18
