VideoHelp.com Forum
  1. Member wulf109's Avatar
    I've tried several DVD players to convert PAL to play on an NTSC TV. They seem to fall into 2 catagories. The first compress PAL's 576 lines to NTSC 480. Round objects appear oval and people are a little shorter. The second type preserves the aspect ratio,round objects appear round,but I suspect thier cutting off the top and bottom 48 lines in the PAL picture.
    Am I guessing wright about this? Are there any DVD players that make a "correct" PAL to NTSC conversion? Wouldn't a correct conversion require re-sizing the pixels?
    Have you tired Yamaha DVS5650 or DVS5760? They don't SEEM to do that. I may be wrong, though.
    "Half empty or half full, it's still only half a glass" - What Dave Says
  3. Member canadateck's Avatar
    My Philips642 does a very good job of Pal to NTSC
  4. Member MOVIEGEEK's Avatar
    AFAIK no NTSC TV(non multi-system) will show a PAL DVD/SVCD/VCD perfectly,my Toshiba SD4900 DVD player will play PAL but the video is "squashed" vertically.
  5. Member jackal70058's Avatar
    My AMW S99 plays the PAL DVD. It works well as any other. The CH-DVD 300 was supposed to do it but I never got to before it broke.
  1. Replies: 10
    Last Post: 6th Apr 2012, 11:55
  2. AVI NTSC conversion to DVD PAL / Windows Media Player
    By Jadaag in forum Video Conversion
    Last Post: 10th Sep 2009, 16:18
  3. PAl to NTSC dvd projects - Conversion
    By bpinto0805 in forum Newbie / General discussions
    Last Post: 31st May 2009, 02:10
  4. Replies: 3
    Last Post: 27th May 2008, 02:42
  5. PAL to NTSC DVD Conversion Problem
    By squallx404 in forum Newbie / General discussions
    Last Post: 8th Oct 2007, 05:16
