  1. i have a philips dvp642. Currently, the anime i play on my philips is cut off around the bottom, to the point where i cannot read the subtitles. I was wondering if there is a fast way to add a small black border around the avi files so i can read the subs?
  2. i have the same issue with it. But i think you just need to re-encode it and add the border that way. I dont know the sizing. Someone should help out. I get annoyed as well.
  3. Member Doomed Space Marine's Avatar
    If you want to use avisynth to add the borders all you do is,
    AddBorders (left, top, right, bottom) I would try to use 16 for the bottom but they may not be enough you might need 32. I had trouble with this as well with my naruto eps I have, the subs would get cut off on the sides for long lines as well as the bottom. Hope this helps you!
  1. Replies: 4
    Last Post: 16th Dec 2009, 18:23
  2. AVI black borders are too big
    By sensini in forum Editing
    Last Post: 21st Jan 2008, 00:02
  3. Replies: 1
    Last Post: 20th Dec 2003, 12:39
  4. How to encode Avi to SVCD with black borders.
    By Phoenix4 in forum Video Conversion
    Last Post: 4th Sep 2003, 06:08
  5. after avi to mpg conversion i wanna keep black borders
    By rlymp in forum Video Conversion
    Last Post: 11th Oct 2002, 19:08
About   Advertise   Forum   RSS Feeds   Statistics   Tools
