got a new pc hp-media center with windows muvie maker software. i can access the sd card with no problem and download jpg files and jpeg video.
the camera has 3 settings:
camera
vcr
card
what setting should my camera be on when i hook it up to the pc?
i can access the sd card on the camera mode but can't caputere tape on any connection. it always prompts me to check my connection.
Do i need to use the s-video cable to connect or is the
OR Do i need to change a video output setting on the camera?
Thanks for all the help.
ofilms.
indie b-cause of the freedom
Should be on VCR, you connect it the computer with a firewire cable. As soon as you connect it and turn it on to VCR you should get the sound when you connect a device. At this point in time you should be able to see thew cam in my computer.
Open up a program that can capture video.....
The camera only comes with a USB cable for retrieving photos. You need to buy a firewire cable in order to transfer DV.
Capture progressive mini-dv tape on interlaced mini-dv cam ?
By alip in forum CapturingReplies: 4Last Post: 8th Feb 2011, 17:27 -
mini DV tape into computer
By caseyrunning in forum CapturingReplies: 4Last Post: 24th Apr 2010, 02:42 -
Mini DV tape playback issue
By jlegrand in forum MediaReplies: 2Last Post: 15th Sep 2009, 10:30 -
How to Fix My Scrambled Mini DV Tape?
By heydudeitsme in forum Camcorders (DV/HDV/AVCHD)Replies: 2Last Post: 9th Apr 2009, 22:01 -
Urgent Help! - Panasonic Mini DV NV GS series tape drawer problem
By kwame in forum Camcorders (DV/HDV/AVCHD)Replies: 0Last Post: 10th May 2007, 13:28
Statistics
Newest guides
Latest tool updates
New media comments
