I have searched the forum but could not really find an anser to my problem. I recently got the Philips DVP642. It plays regular dvds fine and also SVCD's with no problem. However i have tried a few xvid's and that's where i have problems.
The xvid's seem to play fine for awhile and then the audio gets messed up. The audio just starts making a loud sort of whirring sound and any music or dialog cannot be heard anymore. Sorry i can't describe it completly. I tried pausing the movie but it dosen't help. It's random in when it happens. Nothing seems to fix it either.
Any thoughts, it's really frustrating!
UB
Thread: Help with DVP642 Audio!
I asume you mean xvid and not xvid or divx. You might try double clicking on the System Menu button on the remote control. This might give better support for xvid files as opposed to divx files.
On some files with mp3 audio I have a popping noise, check with Gspot and they are always VBR mp3 at around an average of 192 kbps I think it's because of VBR cause it would happen when when there is little sound followed suddenly by alot of sound and the bitrate skipes too high
Anyways if the file works OK on your computer just open it in VirtualDub/VirtualDubMod and re-encode the audio 9 I use Lame CBR at 160 or 192 and they have worked great on my player)
Remote for Philips DVP642
By Melina in forum DVD & Blu-ray PlayersReplies: 2Last Post: 10th Jun 2010, 21:54 -
Phillips DVP642/37 help with DTS Audio problems
By cram_it_2000 in forum DVD & Blu-ray PlayersReplies: 6Last Post: 24th Sep 2008, 14:29 -
DVP642 - Did they ever update the Firmware?
By kelemvor in forum DVD & Blu-ray PlayersReplies: 3Last Post: 21st May 2008, 08:50 -
phillips dvp642
By bored23 in forum DVD & Blu-ray PlayersReplies: 8Last Post: 11th Mar 2008, 06:54 -
Output resolution for Philips DVP642
By cheerful in forum DVD & Blu-ray PlayersReplies: 1Last Post: 2nd Aug 2007, 23:41
Statistics
Newest guides
Latest tool updates
New media comments
