VideoHelp.com Forum
    My ultra-compact Koss DVP2161 DVD player finally burned out on me. Great little gadget, but it had terrible overheating problems. Anyway, I'm looking to replace it, and I'm hoping for recommendations.
    Important:
    Physically compact in size (it's going on top of a 13" TV, secured with velcro. I'm using four six-sided game dice as risers for airflow)
    Low cost (under $100, the cheaper the better)
    High availability (want to be able to buy it at a chain store if at all possible)
    High media-type compatibility (CD-R, CD-RW, DVD+/-R/RW...)
    High data-type compatibility (DVD, VCD, SVCD, ...)
    Well-designed (I'd like to avoid the heating problems I saw with the Koss)
    Not Important:
    Enhanced audio features (planning on using TV's speakers only)
    Component output, S-Video (the TV only accepts RCA jacks)
    Except for the heating problems, the Koss was perfect for the job. Can anyone offer suggestions? Many thanks.
  2. Member mastersmurfie's Avatar
    don't know about the availability locally, but maybe worth a look:
    http://www.newegg.com/app/ViewProduc...107-014&depa=0
    mastersmurfie
    just a thought
    mastersmurfie
    Good find; many thanks. I'll see what I can learn about this gadget. The DivX support is appealing.
  4. Check out the Cyberhome CH-300. It's available at most Best Buy stores for under $50.
    http://www.cyberhome.com/products.asp?Product=300
  1. Replies: 13
    Last Post: 30th Nov 2009, 21:33
  2. Replies: 11
    Last Post: 9th Apr 2009, 16:07
  3. Help with finding dvd player for a non-HD tv
    By missvanderhoven in forum DVD & Blu-ray Players
    Last Post: 19th Mar 2009, 13:35
  4. Replies: 13
    Last Post: 7th Dec 2008, 14:20
  5. Need help finding a VCR/DVD Combo Player that is CT-2 Friendly
    By elling in forum Newbie / General discussions
    Last Post: 6th Sep 2007, 18:39
