VideoHelp.com Forum
Thread: DVD Regions?
  1. Hi all, just wondering whether you can watch Region 2 DVDs in Region 4 (Australia) without needing a multi-region player as I've heard from a couple of people that it's possible?
  2. Member daamon's Avatar
    You might be able to hack the player into a multi-region... See "DVD Hacks" link to the left for the player in question.
    If it's on the PC you're talking about, you can get software that bypasses the region setting and so is effectively multi-region. DVD Region Free is one example...
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
  3. Member Forum Troll's Avatar
    One other way is to rip it to your computer with DVD Decrypter, this makes it region free, then burn it to a recordable DVD.
    You are in breach of the forum rules and are being banned. Do not post false information.
    /Moderator John Q. Publik
    I live in UK, and most movies I buy say on them Region 2+4, so i think that most will play as ok. I have ordered DVDs from the web and I have got a R4 version (as they are dual coded) and they play perfect on a region 2 only player. I think since UK is R2 PAL and Aus is R4 PAL they are just the same.
  1. Various Regions PAL DVD's
    By dblan9 in forum Authoring (DVD)
    Last Post: 11th Mar 2010, 17:10
  2. Code to allow DVD use on all regions
    By eaglet in forum Newbie / General discussions
    Last Post: 29th Mar 2009, 11:04
  3. Data DVD Regions?
    By cyberdrugi in forum Newbie / General discussions
    Last Post: 3rd Dec 2007, 14:06
  4. XBox 360 HD Drive and HD-dvd - regions?
    By elfranko in forum DVD & Blu-ray Players
    Last Post: 13th Nov 2007, 11:15
  5. How to change regions on a DVD or TV?
    By SnowStormWolf in forum Programming
    Last Post: 8th Jul 2007, 17:11
