Many times I downloaded SVCD's. They were in VBR format, and very close to 800mb file size. By close I mean by 2mb, more or less. Anyway I've been trying to convert my own SVCD's lately in VBR format and I NEVER am able to fill a CD. Using CBR it's easy, however when using VBR I get file sizes of 720-745mb. The whole point of vbr is to improve quality, I don't want wasted space on my cd. Anyway I know that vbr, variable, is difficult to calculate to fill the CD so I use tmpgenc to do it automaticly, however since I am not getting the same results can someone please tell me why? How can I fill a CD with VBR? The SVCD's I downloaded before were perfectly full and encoded in VBR.
Thread: VBR, unable to fill CD
If you are using any form of 1-pass VBR then you can never completely predict the resulting file size. You have to do at least 2 passes to do the calculation.
Perhaps TMPGenc's internal bitrate calculator is not the best. If you look in the tools section there is a java one that works well enough, or you can try FitCD which will allow you to account for all the overhead that will go into your final SVCD. Simply do multipass VBR with the average bitrate that these programs calculate and you should have no problem coming within 1MB of your target size.
It's also possible your movie doesn't have a lot of motion, so with 2 pass vbr it's possible many of the scenes are close to your minimum bitrate and not a lot of scenes need the maximum. When I used to make svcd's most of them would be ~800 but others just wouldn't need the bitrate and were smaller.
MTS unable to play in WMP11/unable to edit in Movie Maker
By xxx4reggie in forum Newbie / General discussionsReplies: 6Last Post: 22nd Nov 2011, 23:04 -
Pinnacle is leaving gaps, that i cant fill..........
By jorisss in forum Newbie / General discussionsReplies: 0Last Post: 9th Dec 2010, 13:28 -
What do these option do and what to fill in these?
By tendra in forum Video ConversionReplies: 0Last Post: 30th Oct 2009, 21:17 -
Unable to burn DVD, unable to access the Video_TS.ifo.
By Asymmetry in forum Newbie / General discussionsReplies: 3Last Post: 17th Aug 2008, 23:02 -
16:9 doesn't fill my widescreen TV?
By the_doc735 in forum Video ConversionReplies: 41Last Post: 31st Jan 2008, 12:12
Statistics
Newest guides
Latest tool updates
New media comments
