    Anyone else running into problems with the optical output on this piece, ESPECIALLY when watching DIVX/XVID??? Mine is DAMN noisy/static-ish when using the optical into my Denon.
  2. use the coaxial output then, I don't have any problem with the coaxial output. I reckon coaxial always sound better than optical anyway.
  3. Probably your receiver is sucky, I am using optical out on a harmon kardon and it sounds awsome
    8) wildo2ne
  4. Member doppletwo's Avatar
    What is your audio Output setting? On the DVD player.
  5. Probably your receiver is sucky, I am using optical out on a harmon kardon and it sounds awsome
    Depends on what type of sound you listen to. Listening to classical music DVD, I find optical a bit harsh, but the dynamics of optical is better, so the explosion sound is more dynamic with optical output. Personally, I couldn't care less how loud the explosion sound on my system.
    So you reckon Harmon Kardon is the best? I'm using Krell, have you even heard of that brand yet?
    The 642 is of course just a second DVD player, as it nowhere fits into high end system. But then, I don't think there is yet a high end DVD that plays DIVX.
  1. Does your sound card need drivers to use optical output?
    By Obamargarine in forum Software Playing
    Last Post: 24th Feb 2009, 14:39
  2. Possible to output hdmi and optical output on the ps3??
    By mrswla in forum DVD & Blu-ray Players
    Last Post: 3rd Feb 2009, 16:17
  3. DVD Player Optical Output
    By jcook5000 in forum DVD & Blu-ray Players
    Last Post: 6th Dec 2006, 12:32
  4. Philips 642/17 & 642/37 - What's the difference?
    By prime.8 in forum DVD & Blu-ray Players
    Last Post: 11th Feb 2005, 20:39
  5. HDMI and optical output on Denon 3910
    By kocsis in forum DVD & Blu-ray Players
    Last Post: 11th Jan 2005, 11:11
About   Advertise   Forum   RSS Feeds   Statistics   Tools
