VideoHelp.com Forum
Thread: Splitting help
  1. Hi all im trying to split a 1.28gb mpg file into 2 parts so i can put it on VCD.
    The prob is the first part will play and burn fine but i cant et the second pat to work.
    Can someone please help me ive tried most of the programs and no good,
    Thanx in advance,
    wolverine
  2. Member Dhruv's Avatar
    Have you tried using TMPGEnc? That's generally the best for cutting.
    I only dream in black & white...
    MSN: paschendale@gmail.com
  3. for VCD TMPGenc is a way to go. Splitting mgeg file you need a sepecific software. Make sure you set a VCD type correctly ie MPEG1 Video-CD or MPEG1 Video-CD nonstandard. You can find this tool under "MPEG tools" in TMPGenc.
  1. How do I keep DV files from splitting ?
    By RWANDREWS in forum Capturing
    Last Post: 15th May 2010, 03:07
  2. Splitting with MKVmerge
    By carlmart in forum Video Conversion
    Last Post: 22nd Dec 2009, 19:59
  3. Help with splitting
    By stinger161 in forum Editing
    Last Post: 29th Oct 2009, 17:58
  4. Splitting Divx
    By acestu in forum Editing
    Last Post: 24th Jun 2009, 20:21
