Hi guys. I'm thinking of buying a BenQ 1620 burner, which are $77 here in Toronto, and I'm wondering: Have any fellow Ontarians tested the BenQ media w/ the BenQ 1620?
Thanks in advance,
MJ
Results 1 to 11 of 11
Benq does not make media, they buy it and stick their label on it. Having a Benq burner doesn't make the media any more compatible and if you buy it you are taking your chances.
Hello again Zippy. I believe it was posted elsewhere that the FS BenQ media has SONY D081 media code or something like that.
Is that good?
- MJ
EDIt: The mefia code = SONY08D1. My bad.
Apparantly Daxon, who makes the discs, is owned by BenQ.
A search for the daxon media code turned up this page. Doesn't seem too bad if that's what it is.
BenQ 1620 drive has got a Philips chipset, that is great with DVD+R disks but not with DVD-R disks, so best choose is DVD+R disks.
With firmware B7S9 (or higher) this drive works really well also with DVD-R.
Just my 2 cents !Minds are like parachutes. They only function when they are open !
BenQ discs are usually junk Media ID's.
And then the drive itself is pretty crappy compared to Pioneer or LiteOn drives.
You're asking for double trouble.Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
Here in BC the difference between a Benq drive and a Pioneer is $20. I bought the Pioneer.
Hi. Does anyone know the media code for the BenQ FS +R discs?
Thanks,
Jie
P.S. Zippy, you live in B.C.? How many more Canadians are on here ^_^
P.P.S. Does anyone if Chinese can be input on the board?
Stat page, click here.Originally Posted by Ma_Jie
They're made by Daxon with Daxon MID as you can see in the media list here. The 8x discs are actually supported at up to 16x speed on the DW1620.Originally Posted by Ma_Jie
BENQ DW1670 issues
By kyrcy in forum DVD & Blu-ray WritersReplies: 1Last Post: 30th Jan 2010, 17:00 -
Looks like my benq 1620 may be dying, any writers burn 8x @ 12x?
By Denvers Dawgs in forum DVD & Blu-ray WritersReplies: 10Last Post: 27th Jul 2009, 12:05 -
Benq 1620 tray will not open? Just makes a click sound.
By Denvers Dawgs in forum ComputerReplies: 5Last Post: 23rd Jul 2009, 00:12 -
BenQ DW1640
By jeet49 in forum DVD & Blu-ray WritersReplies: 2Last Post: 12th Nov 2007, 17:48 -
Benq 1620 $25 after instant savings
By bevills1 in forum DVD & Blu-ray WritersReplies: 4Last Post: 16th Oct 2007, 10:01
