Hello Everybody,
I'm am having a problem with the playback of some dvds that have been backed up using dvd shrink. These play fine once, even twice, but after they sit, they tend to stop playing properly. They start to freeze and skip and not play at all. I do put printed labels on them and have been told just to label them with a marker, but if that is the problem shouldn't they not play the first time? Any ideas would help, I'm getting a lot of coasters and would like to be able to have backups of my favorite movies. Thank you for any help.
Dennis
Thread: Playback Gremlin
Sticky labels can screwup the playback of your DVDR's
It may well be that the labels are fine to start off with, but after a few hours play time, the glue heats up and causes the discs to go out of balance.If in doubt, Google it.
That makes sense, but how does one label a disc? They make all these special labels, is there a certain disc I should get that will not allow the label to heat up or should I just get a marker and practice my writing? Thanks for the quick reply
Either a marker or look at getting printable discs, and then can use a printer such as the Epson R200 or Canon i865 (for people outside of the Americas) and print the images directly to the discs themselves, instead of onto labels.
Use a marker let your girlfriend or your little sister write the names on the disc.
Ladies are good at making Purdeee letters.
Pinnacle 11 - playback issues on DVD - rapid playback problems
By crven in forum Newbie / General discussionsReplies: 5Last Post: 15th Dec 2007, 10:19 -
VCD Playback/MPEG ISO Playback issues
By TypicalJeff in forum Authoring (VCD/SVCD)Replies: 2Last Post: 1st Jan 2004, 14:35 -
Stuttering DVD-R Playback on Set Top, No Playback on PC
By kionel in forum Authoring (DVD)Replies: 9Last Post: 29th Jun 2003, 14:32 -
Standalone dvd playback quality differs from writer playback
By Thepert in forum Newbie / General discussionsReplies: 6Last Post: 9th Nov 2002, 09:39 -
NTSC playback to PAL playback problem on Pioneer DV-344
By SGB in forum DVD & Blu-ray PlayersReplies: 0Last Post: 15th Sep 2002, 00:58
