VideoHelp.com Forum
  1. Hi I have a PAL .img file from a DVD movie and I was wondering what would be the easiest way to convert it to NTSC. It has all the vobs and everything that is included on a DVD. Also if I took the main vob files and converted them with MPEG2Works would this work or how would I go about converting the whole image file. THanks again!
  2. If you have MPEG2Works you should have a copy of DVD converter which came with the bundle. That's your best bet for standards conversion of DVD.
  3. I have used DVD Converter for a couple of PAL DVD conversions .... it work and gives pretty good quality too. Don't panic about how long it takes. For my recent DVD conversion (1 1/2 hrs video) it took about 3 hrs to convert.
    If you have DVD Studio Pro you can put back the menu, bonus features etc. to the way it was originally. Depending on how extensive the menus etc. are add between 10 mins and a couple of hours.
    Good luck!
  1. convert img movie file to ?
    By dude905 in forum Video Conversion
    Last Post: 14th Apr 2011, 21:34
  2. How to obtain a tiny sample of an *.img file from a huge *.img file
    By lousk in forum Newbie / General discussions
    Last Post: 16th Nov 2010, 08:03
  3. Replies: 5
    Last Post: 27th Jan 2010, 23:51
  4. PAL DVD-R.img
    By php111 in forum Newbie / General discussions
    Last Post: 10th Apr 2008, 17:05
  5. IMG file, no sound??
    By newtonnjd in forum Newbie / General discussions
    Last Post: 14th Jun 2007, 18:56
