  1. I want to use the HDMI output for video on the Denon 3910, but use an optical output for audio. The instructions manual is not too helpful, but it seems to suggest that if you use HDMI, the audio will come out thru audio outputs including optical as only 2 channel. Any suggestions/experiences?
  2. Member Krispy Kritter's Avatar
    Regardless of which Video output you use, the optical outputs will be true to the source.
    Google is your Friend
  3. Member HatchetMan's Avatar
    HDMI is great for both audio & video if your receiver has HDMI input. If only the TV has HDMI (or DVI, then need adapter) then connect HDMI to TV for video and optical from player to receiver for audio.
  1. Should I get the hdmi/optical cable for my xbox 360 replacement?
    By yoda313 in forum Newbie / General discussions
    Last Post: 23rd Oct 2009, 16:21
  2. Possible to output hdmi and optical output on the ps3??
    By mrswla in forum DVD & Blu-ray Players
    Last Post: 3rd Feb 2009, 16:17
  3. HDMI out vs. Optical out
    By toneystone in forum Audio
    Last Post: 20th Oct 2008, 23:09
  4. DVD Player Optical Output
    By jcook5000 in forum DVD & Blu-ray Players
    Last Post: 6th Dec 2006, 12:32
  5. Philips 642 and the Optical Output
    By Scooter_NJ in forum DVD & Blu-ray Players
    Last Post: 12th Jan 2005, 19:07
About   Advertise   Forum   RSS Feeds   Statistics   Tools
