Relevant Specs:
120-GB IDE ATA Internal WD HD (O/S, Applications, Data, Restore Points)
250-GB IDE ATA Internal WD HD (Video Projects, Data Backups)
160-GB SATA Internal Segage HD (Video Projects, Virtual CDs)
60-GB External Firewire HD
Total HD ==> 590-GB
Believe or not I need more harddrive space.
My Case (Antec) will support another internal 3.5 harddrive.
My Motherboard, (Intel D875PBZ) will support another SATA drive. Currently all my drives (harddrives & 2 optical drives) are own their own channel. (I have a PCI controller card installed).
So, my install options for my new Seagate 160-GB SATA drives, which I just ordered today and matches exactly the SATA drive I alreay have are:
1) Install it and run it as another harddrive
2) Install it and configure it for Raid 0 (I'm not considering Raid 1) with its sister drive.
Everything I read seems to indicate that I really won't see any improvement of a Raid 0 versus two independent drives ... Is this true?
I'm seeking opinions on whether I should run them as two drives or in a Raid 0 configuration..
I just hate having a capability (such as my MB supporting raid) that I don't use. But, if there is no payoff and the pain & risk for configuring to run raid 0 is significant ... what's the point ... run them separately.
Results 1 to 17 of 17
2 drives
IMO, RAID0 is completely useless
RAID1 is great for your OS drive
Also IMO, (hardware)RAID5 is the only way to go
You will likely see some speed increase with RAID 0. The real problem with RAID 0 is that if one drive fails, you loose everything. Although I have only had one failure with IDE RAID 0 array.
Most modern drives, especially SATA drives are probably fast enough for most anything you do without RAID 0. I use RAID for combining drives to one larger drive more than trying to get a speed increase.
If you are just interested in speed and not data lose, they work fine. Two 160s should give you a 320GB drive with faster access times and possibly faster throughput, although that depends on your controller.
You can do a speed test with SiSandra to check it.
I don't really see a need for RAID 0 by itself. You really only start to see some great effects of striping when you're doing it across four or more drives. What is it you're planning on doing with it that you would need to set up an array? For the size of those drives I'd just leave them seperate, that's a lot of data that could go to waste if something were to go wrong.
FB-DIMM are the real cause of global warming
Thanks for the opinions.
My plans for these two drives is for Video work ... capture, edit, encoding, authoring, ripping. So they won't contain any data that couldn't be replaced.Originally Posted by rallynavvie
What in the heck is RAID5?Originally Posted by stiltman
Good idea ... I rountinely check my system using this utility. A typical benchmark result for my SATA drive is:Originally Posted by redwudz
Index: 31848 kB/s
Buffer Read: 89MB/s | Sequential Read: 46MB/s | Random Read: 8MB/s
Buffer Write: 97MB/s | Sequential Write: 46MB/s | Random Write: 11MB/s
Access Time: 6 msec
RAID 5 = striping with parity. It requires 3 or more drives. One of the drives is not used as available storage, it is used to keep the parity data. It is fault tolerant. If one of your storage drives fails, you can replace the drive and rebuild the array using the parity data. It's faster than Mirroring and safer than striping, but you lose one drive's worth of space. For examples, a RAID5 array with 3 120GB drives will yield 240GB of storage.
Nothing can stop me now, 'cause I don't care anymore.
Also hardware based RAID is faster than Software (OS) based RAID
You can also run RAID 5 in SoftRaid, on my ASUS AN8-SLI Deluxe I run my 2 Raptors on Nvidia Raid 0, and my Plextor PX-712SA on Silicon SoftRaid 5...
More details on that one please. What does your Plextor burner have to do with your RAID array?Originally Posted by Pop's
That was the first time that I've seen this. I thought it was hilarious. Was this for real, who was the actor and was it used commerically?Originally Posted by stiltman
My Plextor is a SATA drive, not IDE...
http://www.videohelp.com/forum/profi...rofile&u=25733Originally Posted by rkr1958
You be the judge
Originally Posted by ViRaL1I get the SATA part, where does RAID figure in?Originally Posted by Pop's
If anyone's interested in an inexpensive RAID setup, it looks like CompUSA has 80GB 8MB cache drives 1 for $50, or 2 for $80.
They're labeled 'Generic' but judging from the ATA133 speed and the MFG part number of L06P080 I'd say it's a safe bet they're Maxtor. I personally haven't had problems with my Maxtor drives, but everyone's experience is different.
The price that it links to doesn't seem to jibe with the ad as of yet, so you might want to call your local store of the 800 number before buying.
EDIT: The direct link doesn't seem to work. Go to CompUSA's site, click on Store Ad under the Departments section on the left side. Then click 'View Interactive Version.' It's on the 1st page, top right hand corner.Nothing can stop me now, 'cause I don't care anymore.
hmmmm
linky no worky for me......
JSB
I ordered my second SATA drive from Newegg.com on Saturday, got it and installed it yesterday (Tuesday) and configured it for RAID0 today (Wednesday). What the heck I thought ... I paid for a high-end Intel Motherboard with RAID capability and I might as well use it. Boy does it smoke ... SiSandra benchmark was:Originally Posted by rkr1958
Index: 72713 kB/s
Buffer Read: 119MB/s | Sequential Read: 111MB/s | Random Read: 11MB/s
Buffer Write: 119MB/s | Sequential Write: 106MB/s | Random Write: 17MB/s
Access Time: 5 msec
I like the fact that both drives are treated as one big drive ... I was surprised that PartitionMagic saw it and treated it like any other drive.
I don't know if the above faster speeds will really mean anything from a practical sense ... but (so far) I get great benchmarks.
Sounds pretty good. I'm going to switch to SATA for my next computer.
I really had few problems with my IDE RAID 0 setup. Once in a while the RAID would fault, but it repaired itself easily with no lose of data. I never kept anything on it but temporary video files, so I really wasn't worried about losing one drive.
Now you will have to try capturing with it and see if it lives up to the read/write speeds.
One thing, if you don't like it, not that hard to separate the drives and use them independently.
Crucial M4 64gb raid or no raid?
By Stealth3si in forum ComputerReplies: 7Last Post: 20th Mar 2012, 04:13 -
RAID controller question...
By RogerTango in forum ComputerReplies: 12Last Post: 21st Oct 2011, 23:59 -
RAID question
By mysts in forum ComputerReplies: 5Last Post: 6th Jul 2009, 15:31 -
RAID 1 reliability question
By piano632 in forum ComputerReplies: 9Last Post: 15th Jan 2009, 02:11 -
RAID-0 Backup Question
By Gromit137 in forum ComputerReplies: 19Last Post: 2nd Jan 2009, 06:47
