VideoHelp.com Forum
Results 1 to 9 of 9
    i'm trying to convert an avi file to a dvd, but once it's encoded it runs slow as hell.
    after watching the avi file i noticed it's frame rate kept jumping every second, but the movie seamed to play fine, like it was at normal steady frame rate.
    does any1 know how to turn it into a constaint frame rate?
    thanks...
  2. VH Veteran jimmalenko's Avatar
    I've never heard of something having a variable frame rate - more likely that your player is choking on some part of the file (can happen with too high/too low bitrates), or your encoder choked (often MP3 VBR audio can do this). Then again, your player may not like the media you used.
    (sorry, I'm struggling without my crystal ball - it's in for repairs )
    What are your source file's stats ? (GSpot 2.52 screen dump would be handy)
    What did you encode with ?
    What did you author with ?
    What did you burn with ?
    What media did you use ?
    If in doubt, Google it.
    video codec: divX 5 4cc: DX50
    runtime: 01:42:55 (154,365 fr)
    x y: 720x336 (2.14:1) [=15:7]
    bitrate: 729 kb/s
    FPS: 25.000
    QF: 0.121 bits/pixel
    audio: AC3
    bitrate: 224 kb/s (112/ch, stereo) CBR
    FS: 48000 Hz
    I encoded using doom9 guide, using tmpgenc.
    Burnt using Nero
    Media was verbatim 2x dvd-r
    hope that helps
  4. VH Veteran jimmalenko's Avatar
    bitrate: 729 kb/s
    FPS: 25.000
    audio: AC3
    FS: 48000 Hz
    Burnt using Nero
    hope that helps
    OK, IMO you're an excellent candidate for my AVI to DVD guide
    What settings did you encode to ?
    Do you have the AC3 plugin for TMPGEnc ?
    stream type: mpeg2
    aspect ratio: 16:9
    frame rate: 25
    rate controll: 2 pass vbr
    avg bitrate: 5700
    min bitrate: 0
    max bitrate:8000
    vbv size: 224
    profile: main profile & main level
    video format: pal
    encode mode: interlace
    yuv: 4:2:0
    dc precision: 9 bits
    motion search: motion estimate
    ADVANCED SETTINGS
    video source: non interlaced
    field order: top first (A)
    source aspect: 16:9 PAL
    video arrange: full screen keep aspect ratio
    thats all the tmgenc settings i think
    i think i got the ac3 plugin, where do i look to find it again? i'm encoding the audio by using besweet, than i use ifoedit to combine the movie from tmpgenc & audio from besweet. Then after that burn it using nero.
  6. Removed - reread the post.
  7. VH Veteran jimmalenko's Avatar
    If you've got the AC3 plugin for TMPGEnc, why not use that to do the audio instead of besweet ?
    i just found where the plugins are, i didn't have an ac3 plugin, i do now though.
    can u see any problems with my settings?
    i tried your guide and it hasn't fixed the problem.
    i watched a avi file in winamp and it says at the bottom the frame rate that it's running at the momment.
    throughout the film it said 25fps constantly, when i played my avi file i'm having problems converting the fps changed constanly ranging from 9fps to 28fps.
    somehow i have a variable frame rate film, that when played looks normal, does any1 know how to fix this?
  1. Converting MKV to PS3 with a variable frame rate
    By hookeyed in forum Video Conversion
    Last Post: 20th Jun 2010, 07:38
  2. Replies: 17
    Last Post: 24th May 2009, 10:26
  3. Replies: 0
    Last Post: 22nd May 2009, 04:40
  4. Variable Frame Rate
    By neoblood in forum Video Conversion
    Last Post: 20th Apr 2009, 15:50
  5. Replies: 1
    Last Post: 17th Jul 2007, 20:01
