Page 9 of 9
FirstFirst ... 7 8 9
Results 241 to 248 of 248
  1. Member FulciLives's Avatar
    I'm thinking of putting together a new system using an AMD 790GX motherboard and the AMD Athlon X2 7850 Kuma 2.8GHz CPU.
    I need to keep the price down but I'm curious how fast it will be encoding?
    Anyone have the 7750 or 7850 Kuma CPU ???
    - John "FulciLives" Coleman
  2. contrarian rallynavvie's Avatar
    Guessing it's going to depend on the encoder and the OS.
    FB-DIMM are the real cause of global warming
    this is my favorite thread!!
    food folks and fun
  4. Member glockjs's Avatar
    E2180@3.03 - Abit IP35-E - G.Skill/Crucial Balli 6GB@DDR2 908 - Ati Radeon 3870@843/2500 - Corsair 550VX - Samsung 400GB HD403LJ - ASUS DRW-2014L1T/Pioneer 110DB - Cooler Master Centurion 5 - Arctic Cooling Freezer 7 Pro
    24+ Hr Blend Orthos Stable
  5. Member cyclometric's Avatar
    Originally Posted by glockjs View Post
    Yeah, it's not great, since you have 4 cores, on a single processor. It should see 4 processors. Unless that is a setting that you input yourself. Maybe 2 procs is the maximum that program can use -- yup, actually, just ran that program on my machine, and it also shows 2 procs, and I'm running a Phenom II x4.
    It is a very old program, and I am sure that is why ... but for benchmarking, this is probably no longer a viable program, then... although for comparison against older machines, it's good to use the same SW to compare results.
    So in a nutshell, it's nothing to worry about.
  6. contrarian rallynavvie's Avatar
    Yes but it is a bit interesting to see what core architecture truly does for you when you don't have multi-threaded apps running.
  7. Member glockjs's Avatar
    ill be honest i was being sarcastic
    i thought 10 sec on 2 out of 4 cores on an amd is actually decent and yes new benchie plz
    TMPEGEnc can only use two cores. This is a benchmark of TMPGEnc, not systems.
  1. Benchmarking Disc Tests
    By Seeker47 in forum Media
    Last Post: 15th Nov 2005, 12:45
  2. Best Benchmarking apps....Real World
    By Dilemma in forum Computer
    Last Post: 23rd Jan 2005, 19:20
  3. Benchmarking??
    By beavereater in forum Computer
    Last Post: 12th Jan 2005, 09:09
Slysofts AnyDVD HD removes DVD and Blu-ray encryption and region coding. More info or download trial!
About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
