VideoHelp.com Forum
  1. Over the weekend, I used the VCDEasy GUI to convert a single MPEG file into a VCD with entrypoints.
    Everything seems to work as intended except for one thing -- if I hit "play" to start playback of track 1, then allow it to continue playing until it reaches the start of track 2 (or later), and then press "next", I get track 2.
    Similarly, if I skip to some other track (say, 7) and let it play until it reaches the start of a later track (say, 10) and press "next", I get the track following the one that I last skipped to (in this example, 8).
    Using "previous" gives similar results -- it skips back to the track preceding the one I most recently skipped to.
    This problem is exacerbated by the fact that this VCD has 76 entrypoints. (It's a collection of very short clips.)
    Is this due to something that I have done wrong in VCDEasy? Or is it a bug (and if so, is it a bug in the GUI which could be avoided if I use some other VCDImager GUI?)
    --John Trussell.
    <font size=-1>[ This Message was edited by: truss on 2001-12-03 10:09:20 ]</font>
  2. Member kabanero's Avatar
    Hi there,
    No it is not a bug, it is limitation of VCD. Look at this guide:
    http://www.geocities.com/medinotes/vcd/chapters.html
    Also you can try VCDComplser. I like it better:
    http://www.algonet.se/~pretzel/VCDComposer/
    Regards.
  3. Have you tried turning 'Use Playback Control' (PBC) on (under options) and/or 'Update scan data offsets' (Settings|(S)VCD Pla..)? I had a similiar problem and turning these on fixed it (not sure which one did it, I turned them both on and it worked so I'm leaving well enough alone).
  1. AVStoDVD Chapter Problem
    By adyf in forum Authoring (DVD)
    Last Post: 21st Dec 2010, 14:03
  2. mkv chapter file problem
    By Bully9 in forum Editing
    Last Post: 22nd Mar 2010, 18:06
  3. Muxman problem with chapter times
    By lordretsudo in forum Authoring (DVD)
    Last Post: 9th Jan 2010, 07:52
  4. VOB2MPG Chapter Extraction Problem
    By murray666 in forum SVCD2DVD & VOB2MPG
    Last Post: 20th Oct 2009, 03:14
  5. Problem with creaing Menu in VCDEasy
    By haris in forum Authoring (VCD/SVCD)
    Last Post: 16th Mar 2008, 08:17
