VideoHelp.com Forum
  1. hi what is the best audio avi file setting for philips 642?
    let say i have a QPEL movie and have to convert it in virtualdub what audio settings (codec should i choose)?
    kb/s? Hz? etc?
    any ideas?
  2. If the source audio is AC3 or MP3 I would preserve AC3/MP3 using Direct Stream Copy for audio in VirtualDub. If not, I usually use same sampling rate as the source for example 44.4kHz or 48kHz and use 128kbps for bitrate.
    But you mentioned QPel which is something ot do with video not audio, I assume that you want to reencode your avi files because they don't play? If so, and it's becuase of the QPel (and/or GMC) then you can just do Direct Stream Copy for audio and reencode only the video and clicking "Load Defaults" in the XviD codec settings and choose quantization value of 4 or 3 or 2. But for me reencoding loads of QPel/GMC AVI wouldn't be fun. I would just get a new player that supports QPel and GMC.
  3. get rid of harware when there's a software fix? weird.
  4. Use VBR MP3, you'll get the best size vs. quality audio.
    I use 192kbps VBR MP3 with all my XviD backups and it sounds great on my TVs, I can't tell the difference with DVD AC3.
  1. Philips DVP-642 16:9 Display
    By wulf109 in forum DVD & Blu-ray Writers
    Last Post: 27th Jan 2010, 12:39
  2. Philips dvp 642 help?
    By imemine in forum DVD & Blu-ray Players
    Last Post: 3rd Feb 2009, 02:22
  3. Philips DVD 642/37 Mostly a Blue Picture
    By Shieh in forum Newbie / General discussions
    Last Post: 3rd Feb 2008, 11:32
  4. First Generation Philips 642 Stopped Playing DVD+R DL
    By somebodeez in forum DVD & Blu-ray Players
    Last Post: 4th Sep 2007, 16:57
  5. Philips DVP-642 and x.264 HD encoding
    By dfishman923 in forum Newbie / General discussions
    Last Post: 13th May 2007, 14:36
