I was wondering if storing DVDs (pressed & burnt) in an attic or basement without temperature controls would cause damage to the discs. At what temperatures would damage occur? What about humidity? Same for CDs?
Sorry if it's already posted elsewhere.
Thread: Cold Weather Media Storage
Same for CDs : 23 to 131°F , 10 - 90% RH
Minds are like parachutes. They only function when they are open !
Yes. 23 (F) is too cold and 131 (F) is too hot. Thse may be some sort of "max" numbers, but I would not do it if you actually care about what's on the media. Room temperature.
Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
If you HAVE to store them in either of those environments (which I wouldn't), wrap them in a blanket and put them in a STYROFOAM chest. Tape the chest lid closed to help reduce humidity problems. DO NOT use any other type of ice chest as they will not protect the discs.
My CD's and DVD's are stored in a place which has a fairly stable temperature
However, in my car I have +- 10 CD's with MP3 music ; being all the time in the car, these are subjected to all kinds of temperatures
Most of them are now 2-4 years old and still perform well
I only had some problems with the earlier Sony CD's: peeling of the reflective layer
i leave them in my car in the player even at minus 30 degrees and never had a problem .. the other day i was playing some cds in there and it was about -10 in the car (i just started it - not warmed up yet)
heat is more damaging ... but as for long term -- i have no idea , maybe i am killing them - but those cds in the car are some of them over 10 years old and still play fine .. i just keep moving them from car to car (or truck) ..
hot summer temps though can warp them for sure if not stored flat - or destroy them completly .. it can go to very high temps in a car in summer .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Recommended blank DVD media and recommended media storage methods
By rcvalle in forum MediaReplies: 3Last Post: 13th Dec 2010, 21:05 -
Best storage media for audio (long term storage)
By The Sumerian in forum AudioReplies: 6Last Post: 6th Mar 2010, 11:15 -
Cold weather and video tape
By Habby in forum MediaReplies: 2Last Post: 29th Dec 2009, 14:12 -
ConvertXtoDVD Media Storage ?!?
By p_l in forum MediaReplies: 1Last Post: 11th Dec 2009, 17:57 -
Is optical media storage more stable than magnetic media storage?
By bevills1 in forum ComputerReplies: 24Last Post: 5th Apr 2008, 04:32
