VideoHelp.com Forum
Thread: HTPC help
    This is my first time try to make one of these. Basically what I want to do is record movies/shows/games from my dish network to a HD to view later or record to DVD.
    Can someone show me what hardware I need to do just this? I dont need extras like radio tuner, etc. Just need to record to HD for later view or I also would like to burn directly to DVDR if it's possible.
  2. contrarian rallynavvie's Avatar
    Hauppauge PVRs or AverMedia PVRs can do this. If you're building from scratch make it easier on yourself and get a copy of XP MCE 2005 so you don't have to use the manufacturer's clunky applications. Or if you're familar with Linux give MythTV a try on FC2.
    FB-DIMM are the real cause of global warming
  1. HTPC-streaming
    By triggerstep in forum Newbie / General discussions
    Last Post: 6th Nov 2010, 09:57
  2. Which Processor for my HTPC
    By Bronx in forum Media Center PC / MediaCenters
    Last Post: 20th Oct 2010, 14:54
  3. Do you have a htpc?
    By yoda313 in forum Polls
    Last Post: 22nd Aug 2008, 21:16
  4. To HTPC or Not to HTPC
    By Bondiablo in forum Media Center PC / MediaCenters
    Last Post: 22nd Oct 2007, 04:50
  5. Converting to an HTPC...
    By hype88 in forum Computer
    Last Post: 10th Sep 2007, 23:14
