VideoHelp.com Forum
  1. Member archaeo's Avatar
    ie, how many rewrites do you usually get out of them? What types of problems do you notice when they start to go?
  2. Член BJ_M's Avatar
    they dont work anymore
  3. Member yoda313's Avatar
    Hello,
    Supposedly something like a 1000 times or so. I don't know what the real world limitiations are though.
    I would imagine that you would no longer be able to format the disc when it finally gives out.
    Kevin
  4. Член BJ_M's Avatar
    really - its a hard answer to answer ... some have reported just a few re-writes and they stopped working (able to write on) .. others have reused 100 times ..
    you should always be able to read though ..
    It seems to me, that it is a delicate ballet, between
    writer and media. Having used pioneer, memorex
    and optodisc rw,s in a pioneer 105. The memorex
    and pioneer discs seemed to march on endlessly.
    The opto's were good for about 10 burns, and then
    fell to the wayside. I purchased a nec 2500a and
    managed to recover all the fallen optodisc's.
    This whole media game is something of a black art.
    Brand name means nothing. Media ID means
    everything. Compatibility between specific burners
    and media can be the crucial element between
    success and failure. Since I got my 2500, my
    success quotient is excellent.
    I hope this has been of some help to you.
    kiki
  6. Member lenti_75's Avatar
    there is no answer. I've been using some Maxell's +RW for 2 yrs, and still good, probably erased them more than 300 times, they are my "tests"....
    when they go bad, you can't erase them anymore, but, you should read them.
  7. I'm a Poll Super Moderator johns0's Avatar
    One other problem i found with dvdrw is bad spots in which data isnt burned.
    Ben Johnson-I didnt take any stereos!
  8. Member archaeo's Avatar
    The memorex
    Thanks for the feedback, it does help shed some light on this. Hearing that quality brands can go on for over 300 burns is good news.
    I'm using memorex RW (which shows a Philips ID) and they have been good for about a year now.
  1. Span multiple discs with video?
    By kruuth in forum Newbie / General discussions
    Last Post: 27th Mar 2011, 09:56
  2. DVD Burner life
    By hibbs in forum DVD & Blu-ray Writers
    Last Post: 23rd Sep 2009, 15:23
  3. Life expectance of DVD's as a Storage Media
    By KailuaKid in forum Media
    Last Post: 11th May 2009, 14:27
  4. Replies: 15
    Last Post: 20th May 2008, 16:49
  5. Further Question on DVD Shelf Life
    By Firewire60 in forum Newbie / General discussions
    Last Post: 10th Sep 2007, 02:59
