Hi!
I have just reinstalled everything on my computer. Before I formatted my C: drive, in VirtualDub, one of the options in the videocompression menu was Mainconcept DV codec. I know for sure that I did not install that codec manually, and my question to you is: Is there any program that you can think of that has MC DV codec 'built in'? I use Vegas 5 and DVDA 2, but none of these has the codec (only MC MPEG). I may have installed some trialversions of any kind, but I can't manage to find out where the codec came from. Now, after reinstall, I have trouble with some of my AVI's that I rendered with VirtualDub, because I used that codec, and Vegas will not show those files in my projects.
TIA
Thread: Mainconcept DV codec
even microsoft DV codec will read MC DV codec encoded files --
but w/ v-dub , you need to install the main concept dv codec OR the panasonic DV codec ...."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Are there different versions of the MainConcept H.264 Video codec ?
By Bansaw in forum Newbie / General discussionsReplies: 0Last Post: 16th Feb 2012, 11:00 -
So is any DV codec better than MainConcept at decoding? Does it matter?
By Asterra in forum Video ConversionReplies: 11Last Post: 20th May 2011, 22:59 -
MXF with JPEG2000 codec in Mainconcept Reference
By lord25 in forum Video ConversionReplies: 1Last Post: 3rd Nov 2009, 09:34 -
Mainconcept DV Codec in VirtualDubMod
By WinSpirit in forum Newbie / General discussionsReplies: 1Last Post: 14th Dec 2007, 23:31 -
Mainconcept DV Codec Vs. The Rest
By SeeNoEVO in forum Video ConversionReplies: 25Last Post: 5th Jun 2007, 08:16
Statistics
Newest guides
Latest tool updates
New media comments
