i have a movie that plays fine unless i ff or time jump then it is terribly outta sync,,it has cbr mp3 audio,,any suggestions,,other then the menu trick![]()
Thread: 642 audio sync
That is a known issue with many players when time skipping or ff. No fix that I have seen as of yet.
Google is your Friend
to get the sound back in sync, you just need to pause the player then hit play again. sometimes I have to do this 1-3 times but it always gets the sync ok again.
covert everything audio and video stream in virtualdub and use a lower bitrate for audio
I read on Jefferson Ryan's website that some Divx files desync when you apply the double-click gimmick to get the semi-transparent background. This affects divx and not xvid according to Jefferson. He says by double-clicking on the system menu that he believes this benefits xvid somehow (and perhaps to the detriment of divx).
I don't know if you were using the semi-transparent background when you had this problem and you were watching a divx file. If you were you can apply HuffyK's modified firmware update. This gives subtitle support without having to double click the system menu.
http://www.cfide.com.br/dvp/630_1109_lat2_v2.1.zip
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 17:15 -
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 15:17 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 16:14
