My friend just purchased a 8x 50 pack of Verbatim DVD+R from Sams Club. When I put them in, Dvd Decrypter said "MCC-003-00". Are these still good? I mean MCC is very good media id?
Results 1 to 10 of 10
Thread: MCC made in Taiwan?
"What It Do"
Huh ?????
I have no problem with them and yes, they are from Taiwan.
I believe I read that Verbatim MCC media made in taiwan is manufactured by CMC, using Mitsubishi Chem. Corp. technology and dyes.
The ones marked "Made in Singapore" are manufactured by Mitsubishi.Some people say dog is mans best friend. I say that man is dog's best slave... At least that is what my dogs think.
corrected. see below.
Still a few bugs in the system...
This is it. This is what all my information has shown.Originally Posted by Skith
TDK, MCC and CMC all made in CMC plant.
But each media uses it's own respective chemicals/processes.
PRODISC may use MCC codes, but it's still PRODISC media.
Not made at a MCC/CMC plant.
This can all get confusing, I know.
Plus a lot of it depends on the validity of the often-scarce information.Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
How come I only get speeds of 4x,6x,8x, and 12x on the media? It says 1x-8x on the spindle. It says those speeds 4,6,8,and 12 are supported on dvd decrypter.
I have 1.18 on my Pioneer 108. So 1x is longer supported anymore? I use Maxell which is TYG01 and has speeds of 1x 2x, and 4x. Why on 8x don't they support 1x or 2x anymore? Lordsmurf what media do you recommend for PS2 backups? Every media is different, right? Some can burn at 1x and others cant? Or what speed do you recommend burning PS2 backups? Would 4x be ok? I can only get 4x,6x,8x,10x, and 12x on the 8x Verbatim DVD+R."What It Do"
Huh ?????
Lordsmurf, there is Verbatim/Mitsubishi branded MCC media made by Prodisc. I have some Datalifeplus 8x +R, 4x -R and Digitial Movie 4x +R discs made by Prodisc (I know they're made by Prodisc by the serial number etched in the clear plastic hub area).
Does anyone know why?Originally Posted by sssax2003"What It Do"
Huh ?????
My guess is that the firmware can only contain so many specific writing strategies and there was no room for 1x or 2x writing strategies for 8x or faster media. I could be wrong. I understand the NEC 3500 doesn't support 1x writing on any media at all. At least with the Pioneer if you bought 4x or slower media you could attain it.Originally Posted by sssax2003
Hmm... first I've heard of it.Originally Posted by Gen-An
This stuff gets more complex as the days go by.
NTSC (Taiwan) <> PAL (Germany)
By domtw in forum Newbie / General discussionsReplies: 1Last Post: 31st Mar 2011, 11:17 -
DVD+R Double Layer Matt Silver 8x Made in Taiwan?
By kyrcy in forum MediaReplies: 5Last Post: 7th Dec 2009, 10:20 -
Media Made in India, Thailand, China or Taiwan.
By DroWni in forum MediaReplies: 1Last Post: 16th Sep 2008, 13:45 -
Maxell and TDK made in Taiwan
By xSimonx in forum MediaReplies: 1Last Post: 15th Oct 2007, 20:58 -
Are Verbatim's 'Made in Taiwan' discs...
By dvdashot in forum MediaReplies: 2Last Post: 8th Aug 2007, 13:55
