VideoHelp.com Forum
  1. I have an Iomega 4216 drive. It's 4X +-R/RW. Has anyone tried buring 8X TY discs on this drive. I have had 100% success with 4X TY. Rima, newegg, now only carry 8X. I saw in another post that TY is discontinuing 4x.
    I am asking because I tried some 8X Maxells, id MXLRG03, and they only burn at 2X. DVDecrypter shows a max of 2X, Ulead DVD MF only burns at 2X.
    This drive is a nec1300 clone, so I've looked at a few firmware hack forums. The latest firmware hacks don't seem to address this.
    Hrm, I've had no problems burning MXLRG03 at 4x on our TDK 0404N (rebadged ND-1300). I used a DOS flasher to turn the drive into a true ND1300A with latest firmware 1.0C; perhaps you should look into that.
  3. Thanks for the tip Gen-An.
    I just looked at:
    http://forum.rpc1.org/dl_firmware.php?download_id=1517
    It has the nec1300 1.0c and also one that's specifically for the Iomega version which will take it to v1.21.
    Has anyone here tried the Iomega v1.21?
  4. I don't know any writer that you can't use TY's on. They are the most compatible media that I know of.
  5. Member Mark_Venture's Avatar
    While I don't have the same burner as you, I have a Sony DRU-500a (4x +/- R, 2.4x +RW, 2x -RW)... I have tried Fuji Film "up to 8x" +R's (YUDEN000T02) in my burner with mixed results.
    See my comments in... http://www.videohelp.com/forum/viewtopic.php?t=250216
    I hope you have better luck.
  6. Originally Posted by handyguy
    I use 4X TY all the time, great discs. The point is that it's getting harder to find 4X TY. Most online sites are only selling 8X TY today. I want to know if someone has used 8X TY on my burner and gotten 4X burns. If it only burns at 2X, then I'll look harder for 4X discs or try another brand.
  7. I got some 4x maxells, made in Japan Tys, from office depot.
  8. OD is usually where I get Maxells. It's getting harder to find the made in japan 4X. Last weekend, I went into 2 ODs, all the 4X were made in taiwan, which are not TY.
  1. iOmega 1tb harddrive fail??? plz help!!!
    By NateDizzle in forum Media Center PC / MediaCenters
    Last Post: 3rd Dec 2011, 15:57
  2. x264 and Iomega ScreenPlay Director HD 1TB
    By Filiprino in forum Video Conversion
    Last Post: 21st Jul 2010, 17:21
  3. Iomega ScreenPlay Multimedia-drive
    By Ogilvy in forum Media Center PC / MediaCenters
    Last Post: 23rd Jan 2010, 08:43
  4. trouble with Iomega ego portable driveS
    By sdsumike619 in forum Computer
    Last Post: 7th Oct 2009, 07:40
  5. Iomega Screenplay Media Drive
    By Trollheart in forum DVD & Blu-ray Recorders
    Last Post: 29th Mar 2008, 17:18
