VideoHelp.com Forum
  1. Anyone want to deinterlace this sample video for me? I tried EVERYTHING and I still don't have a video without horizontal lines popping up randomly across the screen. They only appear for a split second.
    Note: Yes, I know there is macroblocking.
    http://ucsu.colorado.edu/~auyeung/a.avi
    Tell me the procedure.
    Thank you very much!
  2. Member Soopafresh's Avatar
    The interlacing is the least of your problems. BTW, what I think you're refering to as "Interlacing" is actually noise or some type of digital artifact. It shows up as a horizontal line for a split second. It is probably from the original capture.
    Use VirtualDub
    Install MSU Deblocking Filter from http://compression.graphicon.ru/vide.../index_en.html
    Load it TWICE from within VirtualDub
    Yes, you'll still have the few glitches, but your Blocking won't look as bad.
  1. Deinterlacing with TempGaussMC
    By Gr0mk1 in forum Newbie / General discussions
    Last Post: 21st Nov 2010, 01:41
  2. A few deinterlacing questions...
    By SBPP in forum Newbie / General discussions
    Last Post: 16th Nov 2009, 23:42
  3. What is going on with Deinterlacing?!?!
    By jieve in forum DVD Ripping
    Last Post: 9th Aug 2009, 15:23
  4. OS X Deinterlacing
    By ggp759 in forum Mac
    Last Post: 22nd May 2008, 16:37
  5. Replies: 2
    Last Post: 9th Jul 2007, 14:07
