I am capturing a LOT of old video tapes, from a Panasonic Omnivision video tape recorder; using a ATI All In Wonder 9000 Pro - with a Dell 700 Dimension.
These are old movies and television shows that I video-taped directly from broadcast televison.. these tapes should NOT have any Macrovision issues (constant light to darkness, and there is a on and off again white line flickering at the top of the screen.) Yet.. there it is..the effects of Macrovision..
Does anyone know what causes this to happen, and how can I get rid of this problem? I DO have an old "Digital Video Stabilizer RXII"; but it doesn't help in this situation.. and I can't afford a TBC..
Any solutions ? Thanks for your attention !
Results 1 to 18 of 18
Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
Thanks, Lordsmurf.. well.. I guess I'm just gonna have to "grin and bear it".. since I can't really afford any of the TBC's that have been recommended.. . . oh Rats..
There's cheaper alternatives that might work..... Try some of the Sima products providing you can return it if it doesn't work.Originally Posted by GreatSinatraFan
The lines you see at the top are teletext lines but the changes from light to dark on the screen are poor signal alinment from the VHSplayer.
My advice would be to try the old tapes you have in other vhs players and see if the films are any better.
Barrybear
Try this:
http://www.checkhere22.com/stabilizer.html
For $29.95 you can't go wrong and it gets rid of Macrovision.
That's a known issue with the ATI cards, they are very finicky about the source. If his captures look anything like the ones from the link LS posted no matter what you do including using a different VCR it won't work. Trust me been there, done that.Originally Posted by barrybear
The only way is to have a good signal before it gets to the card.
Here's a link with some info that goes into detail with example clips from two different cards at the bottom. www.nepadigital.com/mv
Are you sure about that. I see this light to dark all the time when playing a DVD using a VCR to connect to TV. If I copy the DVD and remove macrovision (or whatever), I do not get these light to dark transitions.Originally Posted by barrybear
Therefore I always assumed this light to dark to light transition was macrovision. And if a VCR copies it, it amplifies this transition making the copy pretty bad to watch. Hence copy protection.
That's correct but the movies he has don't have MV. Essentially the card thinks they do. If you removed the MV detection from the card or ATI toned it down a little it wouldn't be an issue at all.Originally Posted by BSR
I'll bet that this is not an issue when he hooks it directly to the TV.
Edit: BTW I tried multiple VCR's including the original camcorder with my tapes.
"GreatSinatraFan" There is a ATI reg tool to turn of copy protection. I know your tapes do not have copy protection but it will tell the ATI AIW not to look for it.
Doesn't work on the new ones unless it's something I'm not aware of that recently came out. It only works from what I have read with particular combinations of older cards, MMC and drivers.Originally Posted by spiderman2k1
I have one of the Video Stabilizer's that pepegot1 suggested & it works. I have used it with both VHS & BETA tapes to make DVD copies through an ATI card with no problems at all. In fact I've had one of these for almost 10 years & used it for making VHS to BETA & vica versa copies for years. I would suggest that anyone having Macrovision problems give it a try. And for $30 it well worth a try.
Well; as I've mentioned in the original post; I have a Digital Video Stabilizer RXII that looks EXACTLY like the one that someone posted in that link ...but this Digital video stabilizer doesn't work at all in this situation.. yep.. when I used this stabilizer in the past, to copy video tapes to video tapes.. the thing worked like a dream.. BUT with my ATI All In Wonder 9000 Pro.. nada.
Hmm;; ya know.. maybe I'll try it with another VCR; wouldn't hurt to try anyway.
Thanks for all the great suggestions..
Ring a Ding Ding !~
Go for it....but if the video plays good on a vcr to tv connection your fucked.Originally Posted by GreatSinatraFan
Now you know why I capture with my JVC recorder instead of my ATI 9800 AIW. I talked to Facet Clarifier people and they said that their unit does not work with the new ATI cards. Therefore, I would assume that the Stabilizer I mentioned above will also not work with new ATI products. ATI shot themselves in the foot with these new cards. If there is a fix-it should be made known or else stay away from ATI no matter how good they are otherwise.
Again, as usual, ATI is not the only company. EVERYBODY is incorporating anti-copy detection. PVRs, DVD recorers, VCRs, capture cards.
Yeah! and that sucks
GreatSinatraFan - another option if you have access to a digital camcorder is to use the camcorder analog pass-through. I've tried many analog solutions and none of them were satisfactory for me. You can also transfer to DV tape then capture via Firewire. Takes more time, but well worth the quality especially for old home video.
Converting VHS tapes to DVD, in particular the macrovision issue
By Taildraggin in forum Video ConversionReplies: 1Last Post: 26th Jul 2011, 06:40 -
What to buy today for Macrovision removal (VHS tapes).
By cowmix in forum CapturingReplies: 3Last Post: 10th Mar 2010, 16:18 -
Getting Macrovision errors on home tapes - what software can help me
By elcondor in forum CapturingReplies: 0Last Post: 16th Nov 2009, 06:54 -
Home vid Vob files won't import
By JackT in forum DVD RippingReplies: 5Last Post: 8th Jan 2008, 00:29 -
A few questions regarding capturing processing and archival of home VHS vid
By ido22 in forum CapturingReplies: 2Last Post: 20th Aug 2007, 02:37
