VideoHelp.com Forum
    So i captured a PAL tape via my newly bought Pyro A/V link..
    Since Adobe Premiere was used for capture, what would be the fastest method to get back out to tape with reasonable quality???
    Here's a few scenarios i've tried...
    1) AviSynth script to resave .AVI into NTSC, import into PPro, re-render.
    2) Open up new NTSC project, import PAL .AVI, and re-render.
    3) Open up new NTSC project, Interpret footage as (29.97) and re-render..
    Seems like all the options are time consuming, require too much diskpace, and very unproductive..
    Believe it or not, I find it much easier to use an AVISynth script, and burn to DVD. :P
    Any suggestions??
  2. Try "ACE" Time Base Corrector. Is allows direct conversion of PAL->NTSC and NTSC->PAL.
    Try locating this UK company through Google.
    This is what i did..
    Reencoded the PAL video to NTSC, via Xsdeeni's guide for 25i source to 29.97i output..
    Since i couldn't get the Smoothdeinterlace() plugin to work, i used FieldDeinterlace() from the Decomb package..
    Output was noticably choppy on tape. Quality was passable. Therefore i'll try a slowdown to 23.976fps, and see if i can somehow get a hard telecine into the video..
    Then proceed to drop back onto the Premiere timeline, and Export once again...
    Essentially, that's what i was doing, but cutting out the Premiere middle man.
    It's easy enough to slow down the video to 23.976fps, with an AVISynth script, but how do i hard telecine a video in VirtualDub??
    Simply changing the framerate to 29.97fps won't work..At least i don't think..
    So this is that i'll attempt to do..
    Avisource("I:\video.avi")
    AssumeFps(23.976,true)
    LanczosResize(720,480)
    ResampleAudio(48000)
    FieldDeinterlace()#From the Decomb package
    From this point, i need to open up VirtualDub, and see if i can hard telecine the video, and FastRecompress via PanasonicDV codec..
    Once this is done, i should be able to drop the resulting video on a new Premiere Timeline, without the need for a re-render, but rather, straight playback, and record to VCR...
  1. Problem converting from digital8 PAL tape to NTSC DVD recorder
    By 1234567 in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 27th Jul 2011, 18:01
  2. Replies: 1
    Last Post: 8th Jul 2009, 00:51
  3. PAL mini DV tape in NTSC camera
    By Berghof in forum Newbie / General discussions
    Last Post: 14th Dec 2007, 23:51
  4. NTSC vs PAL tape help
    By atothedb in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 10th Oct 2007, 20:38
  5. Recording a NTSC VHS Tape with a PAL DVD Recorder??
    By Lanno in forum DVD & Blu-ray Recorders
    Last Post: 5th Sep 2007, 03:42
