Hi,
I use pioneer 107 DVD-RW in an external case and connect to my pc through usb. The case is USB2 but the pc only has usb1 . Ive noticed that suddenly it would take too long to rip dvds. I run the nerotool and it shows 0.7X read while the drive is 16x.. what can be wrong? Does it have to do with dma?
Your PC has only USB1, that's the prob. Buy a USB2 pci card.
Either move the drive inside the computer or add a usb 2.0 expansion card.
Hello,
http://www.videohelp.com/forum/viewtopic.php?t=187112
That sticky in the dvd-dvdr forum has common speed tips in it. You might find some other possibilities in there too.
Though you'll be MUCH happier with a USB 2 port any way - worthy upgrade in my opinion
Kevin
(good call hatchetman
DVD burn runs too hot, how to slow down reading the source disk
By loninappleton in forum DVD RippingReplies: 6Last Post: 28th Apr 2012, 08:31 -
Really slow external hard drive. WTF?!
By dafoe in forum ComputerReplies: 8Last Post: 25th Sep 2008, 03:19 -
NextTech 20X external HD slow lead out error
By Janey87 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 15th May 2008, 13:53 -
Videos stutter from internal drive, but okay off external drive
By ruggrock in forum Software PlayingReplies: 7Last Post: 22nd Jan 2008, 13:17 -
Is It Possible to Make Multiple Drive Images on One External Hard Drive
By drstew in forum ComputerReplies: 17Last Post: 24th Nov 2007, 08:47
Statistics
Newest guides
Latest tool updates
New media comments
