VideoHelp.com Forum
  1. Hey guys
    I need some help. I have a small clip of a movie my friends and I did; and what I want to do is basically remove the backround of the video, and just have my friend and nothing else. The reason is that I want to put a different backround behind him. Any suggestions.
    Oh, I also want to make a movie as if my friend was a ghost. How can I just lower the opacity on my friend so he lookes like if he was faded away.
    Your help is well appreciated.
  2. Member housepig's Avatar
    what's in the background now?
    - housepig
    Housepig Records
    out now:
    Various Artists "Six Doors"
    Unicorn "Playing With Light"
  3. Member edDV's Avatar
    The way to do it in the future is shoot your friends against a bright flat lit green screen.
    Google chroma key.
  4. Member daamon's Avatar
    Hi Jorge,
    If you don't have a single colour background (as per edDV's post), you're gonna have a very difficult if not impossible time getting your friend isolated from it.
    You need to read up on chromae keys and mattes, then learn what Vegas 4 can do and uderstand how it does it, and only then shoot your footage according to the needs of the app.
    I don't know Vegas 4, but I'll base the following on my knowledge and experience of Premiere 6.0...
    As for making your friend look like a ghost, a simple way would be to put the footage of him into another (higher) video track and adjust the opacity with the Vegas equivalent of "rubber bands" (the red line in the picture below).
    Look in the Vegas 4 help files for opacity - there must be something in there...
    Hope that points you in the right direction... Good luck.
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
  5. ok, will do. I'll tell you how it goes.
  1. Sony Vegas how to make this effect?
    By wingfan in forum Editing
    Last Post: 16th Jun 2011, 11:53
  2. VHS effect Vegas
    By Abas-Avara in forum Editing
    Last Post: 30th Oct 2009, 16:47
  3. help with sony vegas effect
    By cadogan in forum Editing
    Last Post: 21st Sep 2009, 16:59
  4. Skin effect plug-in Vegas Pro?
    By jnaizer in forum Editing
    Last Post: 16th Dec 2008, 18:39
  5. Snapshot effect in Sony Vegas?
    By mashimiriam in forum Editing
    Last Post: 28th Aug 2008, 17:57
