VideoHelp.com Forum
  1. Hi everyone. A while ago, I converted my DVD compliant mpeg-2 video to DVD in a very simple manner. I simply renamed the file extension from .mpg to .vob and used IfoEdit to create the ifo files I needed. I was then able to use the "re-author" option in DVD Shrink to open this and save the resultant files to my hard drive with .ifo, .bup and .vob files under .99 gig - ready to burn as DVD - and it worked perfectly. So simple, no extra conversion necessary.
    The problem I am having is that this no longer seems to work. I have tried using different versions of IfoEdit, but all I get is a mesage that says "Could not find any VOB units in the VOB file/s". I have checked my original mpeg-2 file and it was definately rendered as mpeg-2 DVD compliant video, using Sony Vegas. So why will IfoEdit not accept this when renamed to .vob from .mpg? Can anyone help, thanks.
  2. Член BJ_M's Avatar
    a program stream mpeg file is not the same as VOB file --
  3. Hi and thanks. ....but I don't follow your reply??
  1. DVDslideshowGUI stopped creating VIDEO_TS. IFO & BUP files
    By gobettee in forum Authoring (DVD)
    Last Post: 23rd Jan 2012, 14:52
  2. need to join 2 dvd compliant mpeg files (having identival characteristics)
    By perfection in forum Newbie / General discussions
    Last Post: 20th Oct 2008, 10:37
  3. No audio in dvd compliant mpeg 2 files
    By Bertieboo in forum Video Conversion
    Last Post: 14th Nov 2007, 15:35
  4. Replies: 4
    Last Post: 20th Aug 2007, 13:38
  5. creating .ifo from .vob files and keeping menus
    By vishalpatel1 in forum Newbie / General discussions
    Last Post: 10th Jul 2007, 07:40
