Before I spend some real money on PAL DVD discs from Amazon.UK I am hoping that someone has some real experience playing PAL discs on a Philips 642. Philips is no help and according to what I have read it should work as long as I am not using wide screen. I want to get some BBC TV shows that are nowhere else. I will be viewing on a US NTSC TV.
Thanks in advance.
Still a few bugs in the system...
I will test it later tonight, and let you know.
Region 2 UK PAL and PAL SVCDs work on my 27" and 13" NTSC Sony TVs.
PS PAL Anamorphic widescreen plays perfectly with the correct aspect ratio on those sets as well...
Well like the post above says, it does say Pal DVD's, I also tried a CDVD it played it but without sound.
So you guys say it will play PAL DVDs. Thanks much. I'll order today.
You should be able to hear sound by pressing the audio button a couple times until it cycles through the audio codecs. I had to learn this from a poster on this board since it's not in the user manual. I had problems playing mpegs burned onto DVD+RWs until I found out this trick...
Philips DVP-642 16:9 Display
By wulf109 in forum DVD & Blu-ray WritersReplies: 4Last Post: 27th Jan 2010, 12:39 -
Playing PAL DVD on Philips DVP3345V and NTSC TV.
By atarmiga in forum Newbie / General discussionsReplies: 6Last Post: 14th Feb 2009, 19:31 -
Philips dvp 642 help?
By imemine in forum DVD & Blu-ray PlayersReplies: 7Last Post: 3rd Feb 2009, 02:22 -
First Generation Philips 642 Stopped Playing DVD+R DL
By somebodeez in forum DVD & Blu-ray PlayersReplies: 7Last Post: 4th Sep 2007, 16:57 -
Philips DVP 642 (37A) dvd player -does it play PAL
By Katiemay in forum DVD & Blu-ray PlayersReplies: 8Last Post: 11th Jun 2007, 23:16
