Does anyone know of a utility to find blank frames? Trying ( without watching the whole program ) to find those spots when the scene fades to black.
Any ideas would be appreciated.
Thanks,
GRH
Thread: Detecting blank frames
Not heard of one, but that's not to say one doesn't exist.
You could always use some kind of graph to show brightness over the time of the footage - the dips (if dips represent dark spots) will show you where, in the timeline, the black frames are...
But then that then begs the question "Does anyone know of a utility to show the brightness of the footage over time?".
Back to square one... That'll teach me for thinking alound and following my own (circular) logic.
There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
Avisynth can select frames based on average luminance levels.
Set a low threshold and it will find blank frames.
Detecting bad capture, detecting blank screen or static in video files
By dj22 in forum CapturingReplies: 1Last Post: 16th Nov 2009, 00:11 -
Pryo DV capture adds tons of blank frames in between dropped ones.
By Knightmessenger in forum CapturingReplies: 11Last Post: 18th Jul 2009, 16:08 -
Avisynth drops blank frames?
By wfael in forum EditingReplies: 3Last Post: 9th Dec 2008, 22:06 -
Inserting blank frames with logos before movie start
By multiplex in forum Newbie / General discussionsReplies: 9Last Post: 1st Oct 2008, 20:30 -
Insert blank frames at end of video
By kidcash in forum EditingReplies: 5Last Post: 28th Jan 2008, 04:52
Statistics
Newest guides
Latest tool updates
New media comments
